Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 95 guests, and 0 robots.
Topics128,274
Posts1,058,433
Members48,490
I was told my engine is a 1955 Chevy 235 in line 6.
This is the number on the block is 3836288 and below that is GM 11.
Can anyone verify the engine I have.
Thanks.
3836233 is a '55 block .
Whats the number stamped on the machined surface next to the distributor?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Dusty nailed it. Be sure to keep your distributor, the 1955, 235 is a newer type than all previous types. I ordered a 235 OEM several years ago and it will not fit 54 back. Doc.
That actually depends. It is true that the pre 55 distributors are different then the post 55 2403 distributors. The differences are in the lobes, points, rotor and cap. But my decades old delco remy books all provide the later 2403 distributor as a service replacement for the earlier distributors. If I can get a shot of the page I will post it.
Mike
I think the early and later distributors differ in the material of the gear -- cast iron vs. steel -- due to the change in the camshaft material. But I didn't find any reference... Anybody know what I'm referring to.
This may not be exactly relevant to this discussion.
Professional Novice
2 Offline
