| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 25 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 25 | I am putting a new floor pan and left door frame . The door frame does not seem to line up with the floor pan. Does anyone know the upper hinge to striker plate and lower hinge to rear opening? | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | No. Maybe if I knew what you were working on, I could take some measurements for you.  Carl resident smarty pants.
| | | | | Joined: Mar 2017 Posts: 25 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 25 | | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | 33 1/2" for each. The top measurement was taken from the center of the hinge pillar just above the hinge, and the center of the latch pillar just above the striker plate. The lower measurement was taken from the center of the hinge pillar just above the hinge, and the center of the latch pillar. Carl
| | | | | Joined: Mar 2017 Posts: 25 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 25 | Thank you. Cab was not worth the effort,but I'm to far in. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Been there. Done that. Won't do it again. The one of which I speak now has a $15,000 paint job on it. It was my first Stovebolt which I bought in '88. I am now building it for a guy and it looks better than brand new.
