9 members (MickeyP, papas52, Biermann, Otto Skorzeny, Donf, jmoore, Shade Baby, TS3600, BC59),
118
Mod | | | Forums66 Topics128,162 Posts1,056,949 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | Need some help finding the vin for my 60 Chevy one ton truck. Any help appreciated! Found the max CVW rating plate with 14000 lb rating, and shows trim, paint, and wheelbase info. But can’t find the vin plate. Thanks! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | Attached to the L.H. door pillar on cab, open drive's door, should be about eye level.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Attached to the L.H. door pillar on cab, open drive's door, should be about eye level. Yes, that is what is shown in the illustration at the link given in my earlier post. | | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | Thanks, it is right where you guys said it would be. Thanks!!!! | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Need some help finding the vin for my 60 Chevy one ton truck. Any help appreciated! Found the max GVW rating plate with 14000 lb rating, and shows trim, paint, and wheelbase info. But can’t find the vin plate. Thanks! With a 14000# GVW that wouldn't that be a 1-1/2 ton not a 1-ton...??? The chassis serial number will also be stamped on top of the frame rail, drivers side above the axle...you might have to scrap and brush to find it. The numbers are about 3/8" tall. Mike B  | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | With a 14000# GVW that wouldn't that be a 1-1/2 ton not a 1-ton...??? Right, at 14,000 GVW, he has a C-40.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
