5 members (DadsFirstPickup, Ponchogl, ronsway, Jman, tclederman), 119 guests, and 1 robot.
Topics128,102
Posts1,056,531
Members48,448
Page 1 of 2 1 2
#1355906 04/18/2020 7:28 PM
Hi,
I’m looking for pictures and/or parts for 1940 Chevy 1/2 Ton PU.
Clutch linkage Including the fork
Carb links to the gas peddle
Starter linkage.
My engine came in a basket... LEGO time....
Mike
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
These might be a little helpful? (but, they are not shown as adjustable/tuneable assembles on a truck/vehicle):
- clutch assembly
- clutch pedal
- starter linkage
- carburetor adjustment (not very useful illustration)
I think you will need (hope for) photos by owners?
Rabaut #1355953 04/18/2020 11:53 PM
I think your right about help from owners.
The clutch peddle might be right
It’s hard to tell about the others though....
Appreciate the help....
Mike
Rabaut #1356131 04/19/2020 10:26 PM
This is my '40 , it's right hand drive , just pretend the pic is a mirror image . smile
Rabaut #1356138 04/19/2020 10:51 PM
So, I need a bent fork with a hole for a spring....
The search starts.....
By the New Zealand is a GREAT place..... spent some time there a while back....
Mike
Rabaut #1356141 04/19/2020 11:01 PM
Crusing in the Passing Lane
I was there in '73-'74, on the way to the 'ice' , Model 'A' Fords, etc.
Ed
Rabaut #1356157 04/20/2020 12:57 AM
Yes , I remember Ed, you guys bringing mustangs and monte carlo in and taking our model A's away . smile smile
I was perfectly apply with 'A's, no need to have them.
Ed
Dusty #1356209 04/20/2020 12:00 PM
What was the linkage between the peddle hook and the fork?
How does the spring hook up?
Mike
Rabaut #1356212 04/20/2020 12:44 PM
these clutch photos are my 46. They may help with your 40.
Harold
Harold
Rabaut #1356213 04/20/2020 12:48 PM
these carb links photos are my 46. They may help with your 40.
Harold
Harold
Rabaut #1356214 04/20/2020 12:54 PM
these starter photos are my 46. They may help with your 40.
Harold
Harold
Harold,
Good pictures on what I’m looking for.
I just need to find the fork and hook that connects them.
As to the starter button. The shaft in one picture is fixed while in another picture, it shows a tab that the button shaft screws into.
Any idea which one is correct for my 1940 Chevy 1/2 ton?
Also, your picture of the carb shows an accelerator rod connected to the carb linkage.
Where does the other end fasten? I assume to the gas peddle but any where else?
What does this rod look like?
Again,
Mike
Mike
I think I have the clutch fork and hook in my spare parts collection. These were on a 1940 model engine. I will check today and send you a PM. Do need other parts yet?
46Sparky
As to parts, I don’t know until I find their missing...😀
Mike
Mike:
Sorry. The fork and hook are missing here. Do you have the clutch release fork ball and retaining spring clip?
46Sparky
Any idea which one is correct for my 1940 Chevy 1/2 ton? I would think they all screwed on. it would be difficult to make this part as 1 piece plus it has to go through the toe board.
Also, your picture of the carb shows an accelerator rod connected to the carb linkage. Correct
Where does the other end fasten? Connects to carb linkage and accelerated pedal
I assume to the gas peddle but anywhere else? No
What does this rod look like? I do not recall seeing a 40 Chevy but I found this photo of the pedal & rod on the internet. . This is claimed to fit 32-40.
Harold
Harold
Isn’t the photo with the ruler of the rod that connects the carb to the pivot linkage just below the carb?
I believe there is a rod that connects this pivot to the accelerator peddle.
Bummer on the fork and and hook.....
I do have the fork ball and spring that Holds the fork to the ball. Thanks
As to the starter linkage, I have 2. The first has a fixed shaft with the button screwing on The shaft and a second Where the shaft screws on and the button screws to the shaft.
The pictures posted show both type. The picture just showing the linkage has the fixed shaft where the one showing the bell housing shows the tab where the shaft screws into.
Mike
I have never seen a starter pedal screw on like your 2nd option . But if you check the floor board , see how the hole lines up , it should help , notice that the welded on shaft is in the center and the bolted is a little off set to the left .
For what it's worth, the starter pedal on my '51 screws on to a short shaft that screws on to the tab on the crossbar just like the pic posted by Rabaut. I would assume that there was a change back in the 40's from the crossbar with the welded on shaft.
Interesting....
I have one that is the welded type in the box also.....
Decisions..... decisions.....
and I have no body on the truck to test it....
And the beat goes on.....
I need to find somebody with a complete 1940 truck...
Thanks guys....
Mike
Rabaut #1356294 04/20/2020 10:39 PM
Mike,
You are correct I posted a photo of the Carb. rod. I have corrected my previous post. I know a lot of changes were made on the 42 models which carried forward through 46.
I do not recall seeing a 40 Chevy but I found this photo of the pedal & rod on the internet. This is claimed to fit 32-40.
Does this look like your pedal?
Harold
Harold
Rabaut #1356307 04/20/2020 11:51 PM
Harold,
I have no idea as to what the peddle arrangement looks.
Nothing like that was in the box of junk so it could be it....
mmmmmmm
Mike
Dusty #1356309 04/20/2020 11:52 PM
Dusty,
Do you have any pictures of the gas peddle setup for your truck?
Mike
Rabaut #1356313 04/21/2020 12:24 AM
FWIW, I checked the 1929-1942 Chevrolet Master Parts Catalog and it indicates the starter pedal shaft assembly, group number 2.028, part number 598211, is the same for all models except the cab over, for 1938-1940. The 1940 engine I have has a starter assembly that looks like the one Harold posted, except it doesn’t have a threaded end for the starter pedal. However, I do not know for absolute certainty this pedal assembly came initially with this engine.
Rabaut #1356320 04/21/2020 12:57 AM
I dont have a pic just now , but it will be completely different to yours with mine being RHD
Sparky,
Harold pictures show two starter peddle shaft assemblies.
One alone in the picture showing a welded peddle stud and another one installed over the bell housing with the threaded tab to screw in the peddle stud.
Which are you referring to?
Again,
Mike
Thanks for looking Rusty...
Mike
Originally Posted by Rabaut
Sparky,
Again,
Mike
The Master Parts Catalog info I referenced earlier is for the, “one installed over the bell housing with the threaded tab....
I will add info about the “welded peddle...”, in a follow up post. That part is referred to as the Accelerator Rod, in the Master Parts Catalog.
Mike
The two photos showing a foot pedal and rod are, as I understand the 1929 - 1942 Master Parts Catalog (MPC), the Accelerator Rod, Group number 4.431. I do not know what the part number is for the parts in that photo, but they appear incorrect for a 1940 1/2 ton truck.
The MPC indicates that part number 594457 was used for half ton trucks from 1937 - 1940. I have a 1937 Chevy 1/2 ton and will get some photos for you today. The MPC also indicates the same accelerator pedal was used.
Accelerator rod group 3.431.....
While your under your truck, see if you can take a picture of the exhaust system hangers....
that’s one of the next things on my list.....
Mike
The photo referenced above is the last post made by Harold yesterday showing the rod and attached pedal. I tried to copy and repost here without success.
My ‘37 does not have the original exhaust hangers, so I can’t help with a photo, sorry.
Here are photos of the Accelerator Rod and one showing the pedal. Note on the pedal photo that the hole at top nests the ball end of the accelerator rod. The bottom of the pedal nests or hooks into a bracket on the toe board.
Good shots....
Thanks for the exhaust comment....
So then accelerator rod is one piece? Goes through the firewall .... through some sort of bushing... then attatches to the peddle?
It also looks a little larger at the peddle end...
It looks like it sweeps up towards the firewall then straightens to attach to the peddle?
Thanks for your trouble,
Mike
Good shots....
Mike
Don’t know if originally there was a bushing at the toe board. This one doesn’t have a bushing or mount bracket in the toe board to accompany one. Maybe someone else knows for certain. If there is one, I didn’t find reference to it in the MPC.
The accelerator rod is one piece, bent at about 90 degrees at the forward end to fit into a lever that also holds the bottom end of the throttle connecting rod coming down from the carburetor. The accelerator rod is mostly straight from the lever to about the last 4 inches on the aft end. Yes, it swells in diameter at the end and has several bends.
Rabaut #1356491 04/21/2020 10:35 PM
Mike, there should be a round flexible bushing (not sure what it is called) on your floorboard that the rod goes through to the pedal.
Dennis
40 Chevy 1/2 ton
Rabaut #1356502 04/21/2020 11:47 PM
I’ll continue looking for the rod now that I know kind of what I am looking for.
I have managed to locate the correct fork thanks to the pictures, so all I need there is the connector to the clutch peddle.
Mike
Do you think the accelerator rod looks like this?
Mike
No. The severely curved section on that one should be straight. The ends appear to be almost correct though. The ball end should be a little larger in diameter for about the last 4 inches.
It might be worth trying a call to Jim Carters Truck Parts. They sell used parts as well. Also try a post in the “parts wanted” forum elsewhere on the StoveBolt.
It seems these would be a easy find, but apparently not, it took me a while to find the correct one for my ‘46 some years ago.
Jim Carter’s used parts section is shut down for the duration....
I’ll try the parts wanted section as suggested.
Thanks for the comment.
Mike
Rabaut #1356661 04/22/2020 10:33 PM
How about this
... I feel like a kid rummaging through his toy box....
Page 1 of 2 1 2
