1 members (Rusty Rod), 105 guests, and 2 robots.
Topics128,026
Posts1,055,404
Members48,422
#1354964 04/13/2020 2:05 PM
WR
Offline
Good morning Friends,
My 66 truck had missing the components for the horn at the steering wheel. I installed a new horn kit but the horn activates when I turn the steering wheel. Also, without the steering wheel when I press the column the horn activates too. Please let me know what could be wrong. Thanks
WR #1354998 04/13/2020 4:40 PM
The horn wire inside the column could be worn and shorting against the steering column. It's included with the turn signal wiring. You may need to remove the TS wire loom to find the issue.
Fred
WR #1355040 04/13/2020 9:51 PM
Wr - it may very well be the worn wire in the column, but you may also be missing a piece of the puzzle.
In photo 3. the 3 screws that hold the horn cup down - they are isolated from the column with a plastic collar of sorts. refer LMC catalog pg 71, upper right corner for blow up of components. Check your parts to make sure you have the plastic ring that keeps the screws from touching.
But maybe the plastic ring that shows on photo 1 and 2 does the same? I dont recognize that piece on the steering shaft. Sorry I dont have a good picture for you.
~ HB
1962 Chevrolet C10
1962 Suburban
WR #1356014 04/19/2020 11:36 AM
I had problems with my horn too, so I decided to rebuild the whole column. I’ve rebuilt the columns on my 1965 and 1963 trucks. I decided to document every step in 4 parts.
So I hope something in the rebuild section will help you.
COLUMN REMOVAL
COLUMN DISASSEMBLY
COLUMN REBUILD
COLUMN INSTALLATION
WR #1356749 04/23/2020 2:54 PM
Yes, the plastic piece is in the shape of a ring, originally, it looked more like a nylon ring. It gets put in the there too, as well on the underside of the steering wheel there should be a white plastic piece. This should solve your problems.
WR #1356754 04/23/2020 3:26 PM
I think your upper column bearing is making contact with the brass ring. Anything that connects the brass ring to ground will cause the horn to sound.
WR #1357221 04/26/2020 11:25 AM
WR,
What did you find?
~ HB
1962 Chevrolet C10
1962 Suburban
WR #1357371 04/27/2020 3:15 AM
WR
Offline
Sorry for the delay. I took apart the signal and horn plastic part and I found that the horn wire was making contact with the column. Does any one has a diagram or link for a video for the horn assembly? Thanks for your help.
WR #1357373 04/27/2020 3:18 AM
See my earlier post.
WR #1357374 04/27/2020 3:19 AM
WR
Offline
Ok, thanks
WR #1357422 04/27/2020 1:35 PM
WR
Offline
Very easy understanding after looking to the pictures and explanation. Thanks. What I just found is that the steering is for GMC and later model 67-72, so the pin system that make contact for the horn is different from the chevy 66. I might need to the get the right steering for my truck in order to have the horn working with the original push button. What do you think?
