0 members (), 91 guests, and 3 robots.
Topics128,095
Posts1,056,067
Members48,433
#1355887 04/18/2020 5:24 PM
For areas like a cowl and vent covers that have a lot of areas too hard to sand by hand: Would a small media blaster be okay? Speed is not crucial. I only have a Sears 5HP 20 gallon compressor so I thought I might try the HF 20 lb sand blaster.
1960 C20 Apache Step Side Long Bed
"Swamp Thing" restoration
Story starts in 60-66 trucks
I bought a small blaster from Grizzly Industrial. It looks kinda like a paint gun, has various rubber tips and a bag to collect the grit and dust. Actually works pretty well, but I think you'd run out of air pretty quick with a 5 gal compressor. The instructions recommend a compressor that will provide 11 CFM at 100 psi. Your 5 gal rig won't do that for more than a few seconds. I have a 5 HP 60 gal in my shop.
[on edit] The HF blast gun instructions say it consumes 7 CFM at 90 psi. Still too much for your 5 gal compressor.
Sorry, it is a 20 gallon tank... I changed the post.
I have seen the hand held guns as well. It is an option.
If it's a 5 HP compressor, you'll probably be OK. I like the Grizzly gun I bought as it keeps the dust escape to a minimum.
Insomniac
Insomniac
We used our 2 HP Speedaire compressor to sand blast small areas.
Notes:
*The Speedaire is a belt driven compressor. I doubt that a 2 HP direct drive compressor will be up to the job.
*A good water trap is needed installed in the line or water will clog up the nozzle.
*The nozzle that came with cheap gun wore out very quickly. A good ceramic nozzle will last.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
