4 members (gswbbc, 32Fordpuchoptop, dwreills, Otto Skorzeny), 77 guests, and 2 robots.
Topics128,035
Posts1,055,447
Members48,422
#1354233 04/09/2020 6:07 PM
Has anyone had experience adding a sway bar to the front of a 49 1 ton or similar? If so, where did you get the parts? I've seen sway bars for sale in Jim Carter and Classic Parts mags, etc. However, they generally all say "for 1/2 tons."
On the other hand, does anyone recommend not bothering with them?
Thanks for your help!
WyoFlyer #1354258 04/09/2020 8:30 PM
Offline
Offline
Sway bars are fabulous, especially if you're hauling a load! The other plus is that you can just about fabricate everything but the bar. FOrd has rear bars on their trucks that just use a u-bolt clamp to the axle, and then of course the dog bones to the frame. We bolted on directly on to a 56 GMC rear axle without any mods whatsoever because the axle housing was close enough to the same diameter and there were 3/8 holes in the frame directly above where the dog bones fell!
Just measure your frame width and head for the toy land. Er, I mean, wrecking yard!
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
WyoFlyer #1354551 04/11/2020 3:11 PM
Great, thanks for the info!
Worst case scenario, is there any reason one of the "1/2 ton" sway bars from the online retailers won't work on a 1 ton? I'm not savvy to the little differences in their construction yet. I don't plan on hauling heavy loads with it, if that makes any difference in terms of strength requirements.
WyoFlyer #1354563 04/11/2020 4:13 PM
Offline
Offline
The difference is going to be in how much body roll you get. A sway bar lifts the wheel on the opposite side of the lean. A one ton will just be a bigger bar and subsequent mounting hardware.
Elderly Iron
WyoFlyer #1355735 04/17/2020 5:16 PM
Just did a little research, most of the sway bar kits for the 3100 use a plate that is sandwiched between the shock mount and the axle. Since the 3800 trucks use bigger u bolts and have wider leaf springs, I'm guessing a custom playe would need to be fabricated, unless the holes can be opened up an wallowed out.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
WyoFlyer #1355770 04/17/2020 8:42 PM
Offline
Offline
Since you're going custom, it doesn't matter whether you bolt the bar to the axle and ends to the frame or bar to the frame and ends to the axle. It also doesn't matter if you use the spring mount u-bolts either. You can custom fab every bracket to tuck it in wherever you want, though I don't think you have much choice but to get new u-bolts and make a clamp that fits the spread.
Elderly Iron
WyoFlyer #1355780 04/17/2020 9:37 PM
Good to know. It's always something with these 1 tons! I'm sure I can whip something up around the shop to make it work. Thanks for the help.
WyoFlyer #1355831 04/18/2020 4:12 AM
Insomniac
Insomniac
If you review this previous thread on "sway" bars, you might get some ideas on how to make something to fit...
https://www.stovebolt.com/ubbthread...way-bar-install-trouble.html#Post1331294
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Moderated by  Dusty53
