| | | Forums66 Topics128,181 Posts1,057,174 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 73 PA OUTLAW | | PA OUTLAW Joined: Sep 2017 Posts: 73 | Wanted to replace outer axle bearing rear axle on my 1955 chevy 3100 truck. The ones that I removed were Hyatt OR 1502 made in USA 868 stamped on the outer part of bearing . been to napa and several parts store that bearing doesn't exsist but I have 2 of them ordered from a old truck suppler they came as china wb c1502 does anyone have a good bearing # for this OR a idea or were to find !!!!!! THANK YOU !!!!!!! | | | | | Joined: May 2015 Posts: 11,163 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,163 | The 1502 number is the size used across all brands. What you were sent are probably correct.
NAPA's number should be BRG R1502EL. The parts guy should have pulled out his cross-reference book instead of just relying on his computer. Be ready to say OUCH at the price, however.
Jim Carter has the same bearing for about 1/2 the price. Their item no ME172.
Both may be made in China, however. That's becoming more prevalent.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
