3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1355162 04/14/2020 4:57 PM
I
I Offline
ok here are a few pics of the engine and the stamp behind the distributor on my 46 gmc 1/2
would love to find out what this engine is
thanks for everybodys help[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/17135/filename/gmc engine.jpg[/img][img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/17135/filename/gmc engine.jpg[/img][img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/17135/filename/gmc engine.jpg[/img]
WILLIAM A GOVE
IRR96 #1355207 04/14/2020 7:42 PM
It looks like the first three digits on the Engine Serial Number is "236".
On many GMC engines, the first three digits is the engine displacement.
236 GMC Engine
GMC also developed an OHV/pushrod engine in 1939. The 236-cubic-inch (3.9 L) 236 was produced through 1942. This is a low-deck engine. The bore was 3.625 inches (92.1 mm).
tclederman #1355220 04/14/2020 9:22 PM
I
I Offline
thanks,would you know if these engines were the babbited bearing engine or insert bearings
and are they any good ???,its seems to run great,has a few oil leaks,
would like to find out what rpm they are comfortable at
WILLIAM A GOVE
tclederman #1355222 04/14/2020 9:23 PM
I
I Offline
when you say low deck engine,does that mean lower torque ???
WILLIAM A GOVE
IRR96 #1355234 04/14/2020 10:15 PM
All GMC engines used insert bearings.
Low deck refers to the shorter distance from pan rail to head gasket on engines with shorter stroke.
More GMC data on my site here: http://victorylibrary.com/mopar/m-table-c.htm#GMC
