| | | Forums66 Topics128,181 Posts1,057,152 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | I recently saved a 1960 Chevy truck (1 or 1.5 Ton?). The cab is in pretty rough condition and i was wondering if the cab is the same as a 60 Pickup cab? I assume the front fenders are different given the wheel size. The truck has what i would call a 16 foot or so container on the back, on dual tires. I was told it was used in a carnival to carry various items and as a repair/maintenance truck for other stuff in the carnival. Who knows if that story is true or not, but i did find a helium gas bottle in the back of it. LOL I will try to get some pictures out here soon. I happened to run across a 60 pickup longbox as a possible donor. Any help appreciated. Thanks!!! Gene
| | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Cabs will be the same... Mike B  | | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | Hey thanks Mike!!! Really appreciate it. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Got any pictures of it you can share ? | | |
