4 members (RoadsScholar, DadsFirstPickup, Maybellene, Cletus1950), 128 guests, and 5 robots.
Topics128,108
Posts1,056,233
Members48,437
#1355068 04/14/2020 12:43 AM
My 67 C10 currently has the non synchro 1st gear 3 speed. I’ve purchased a different 3 speed that came out of a early 70s van with the same engine (250ci) that my truck has. I was lead to believe it would be a straight forward swap out. Unfortunately it’s not that simple. It looks as though I’ll need different shift linkage and shorter prop shaft. Does anyone know where I can get the linkages I’ll need & also other things to be aware of?
Crusing in the Passing Lane
It is pretty simple to learn to double clutch the few times one needs to shift into first gear while moving.
Ed
That body style ran until 1972, and those trucks had the fully syncro transmission. Look in the junk yards, online forums for 67-72 chevy/gmc trucks. The drive shaft can be shortened are if your searching junk yards it's probably 3 inches shorter.
Tommy
59 apache 1/2t
261 short stepside
67 6cyl trucks came with the Muncie 318 non syncro trans with the short tail housing. As you found out the differences are the side cover, shift rods, and length. The later Saganaw unit could also could require a fine spline front yoke depending on the year. All of this can be worked around, the rods can be replaced or bent to fit the later side cover and the driveshaft can be modified. The Saganaw is a much better transmission overall and worth the effort. The Muncie is about 15" vs the Saganaw at about 22".
Fred
