0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
#135463 09/21/2006 11:39 PM
Any info or pics on hot built 235's for the big trucks/coe? grin
1946 Chevy 1.5-Ton Flatbed
Photobucket
Old Big Trucks are built to last.
Cajun,
Maybe post in the big bolt section. Do you have a 235? A 235 is a good engine, a 261 is a better one. I'm not suggesting going the v-8 route, but it may provide you with more hp cheaper than a 6 cylinder.
A 235 can be built to put out 200 HP. Usually you will use lighter, higher compression pistons, a hotter cam, a dual or tripple carb set-up... 1 4bbl works well too, headers, and electronic ignition. Ballancing is reccomended, and additional headwork may be in order.
Thanks for the direction to the big bolt section.
However I do like to take the more challenging roads than the obvious easy roads. I appreciate the information on the six cylanders. Last but not least, yes I have a 235 in the truck I just purchased.
Photobucket
Cajun,
A man after my own heart. Welcome to the bolt. I'm sure you have already found this site, but in case you haven't lots of cool pics. http://www.classiccoe.com/oldcoetrucks/COETrucks.html
