5 members (fonz8261, King Kielbasa, Hotrod Lincoln, Otto Skorzeny, 1 invisible), 84 guests, and 4 robots.
Topics128,077
Posts1,056,015
Members48,433
#1354508 04/11/2020 6:24 AM
Drug home a 47 COE a couple weeks ago. It has a dump bead. Planning on keeping it stock for awhile and putting it to work around the house until I finish some other projects. One thing I need though is a pic of somebody's complete hood latch. Mine has just the levers that show on the outside and the hooks on the inside. They are missing something that will grab the hooks. If I see what a complete latch looks like, I may be able to fabricate the missing parts.
Fort Moe #1354545 04/11/2020 2:31 PM
Nice looking COE Moe. I've owned thirty of them. Kept all of them stock.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Fort Moe #1354554 04/11/2020 3:21 PM
Wow, that is a beauty! Congratulations!
1951 1 Ton Completed
Fort Moe #1354567 04/11/2020 4:46 PM
Thanks for the picture Spanky! It will help out a lot.
I have some carburetor parts on order. Brakes are just so so. I have found out that it has a 5-speed Clark tranny (no OD). Dump bed is operated by cable instead of a lever so I'm not sure what type it is yet. It also has a 2-speed axle.This is my first big bolt so I've got some learning to do. The ID plate inside the door is missing so not sure about some of the details but stickers on the side of the door say 22,000 GVW. Supposedly was a farm truck in Eastern Washington for most of it's life. When I get my shop finished I'll get it inside and get it road worthy again.
Fort Moe #1354658 04/11/2020 11:22 PM
Took you a few pic.s
Spanky Hardy
1950 GMC 250 1-Ton
Fort Moe #1354683 04/12/2020 1:17 AM
Nice. Maybe when your done with the house projects, and you decide to let it go? Maybe itll make a sweet tow truck 1 day. thumbs_up
Fort Moe #1354706 04/12/2020 3:03 AM
It looks to be in pretty good shape. Is that the color? or did someone hose it with gray primer?
Another quality post.
Real Trucks Rattle
Fort Moe #1354723 04/12/2020 4:33 AM
Thanks Spanky!!! I should be able to make that missing rod and spring for it with the pics and drawing. Does the top of the big "C" spring have a "hook" that goes into a hole at the top of the catch rod?
Rusty, original color is green almost the same color as my '53 Studebaker 1/2 ton. The truck belonged to a company called Gray's Construction for a while. I'm assuming they are the ones that did the grey paint over everything.
Glenn, I'd love to put a roll-back bed on it so I can bring more cars home.
Fort Moe #1355074 04/14/2020 1:18 AM
Spanky Hardy
1950 GMC 250 1-Ton
Fort Moe #1355085 04/14/2020 2:47 AM
Thanks again Spanky!!!!
