1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
I stumbled across this video, and was intrigued by this guy's method of butt welding a patch panel in. I can't wait to find something to try it on. It is too simple, and makes perfect sense.
I'm glad I watched it.
Very interesting technique.
My only question is, where in the world is Fritzee from, and where has he lived recently to have developed that amalgamation of accents?
I grew up in Michigan, but have lived in Virginia for 40 years, so of course everyone thinks I am from Oklahoma.
I thought he may be Canadian..
I'm thinking Swiss extraction. There's a well know musher, Martin Buser, up here that sounds a bit like him. Martin is originally from Switzerland.
Interesting concept.
Great video. Thanks for sharing it, 4100. Never saw that before. Assuming he's using the 'close your eyes' welding helmet. Very comfortable...
My guess is Irish. With a little Scots. Then transplanted to Ontario.
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
He is from Newfoundland
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Great video. I am a fairly new welder and that has been my biggest fear. Getting an accurate cutout of the patch I am trying to install.
Dave from Northern Kentucky
My 54 3100
The other way to do it is scribe the outline, trim a little big, fit, trim, fit, trim, etc. Doing it that way, you can get a near zero gap. But it's a tedious process.
Newfoundland. Never heard that accent before. It does seem to have a little bit of the Maine accent to it. Just a bit though.
back yard wrench turner
I like his methods. It makes it less scary to making panels for our rusty trucks.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Some casual observations... I would not recommend any novice use a 24 or 36 grit sanding disc on a 7" disc grinder for removing welds. Too much heat generated, can't see where you're sanding, a recipe for disaster when someone sands half the panel thickness away, or worse yet, sands through. Next, if you need to reweld after grinding, turn up the heat, you are not getting a full penetration weld. And now you need to grind again.
Part of the reason we use butt welds is to duplicate the original metal "flavor and feel" so that when someone looks in the trunk or under the floor pans, they don't see a flange repair, or have to contend with ghost lines on exterior painted panels. We can effectively cut out damaged (rusty) metal, butt weld in a new section, planish/metal finish/filler as needed, and we can have an invisible repair that for all practical purposes should be a permanent repair. The patch is normally already shaped to match (in the case of repops) so that the crown of the patch matches the existing panel. (NORMALLY) Part of the reason you see recommendation to use TIGHT butt welds, is that it eliminates open area that allows any panel movement, ie: as the weld shrinks, the panel pulls together. If the crown of our patch used to match prior to welding, weld shrinking along with the panel's pulling closer together (due to the gap) is going to pull in some of the crown. If it is a flatter crown, such as the middle of a quarter panel or top of a roof/hood, it is more noticeable as the crown in these areas is normally minimal/just enough to maintain the shape, and may result in oil canning. If it is a concave crown, such as a reverse where the wheel opening flare comes outward, then the weld seam has a tendency to pull outward as it shrinks. The following pictorial shows an exaggerated crown and gap primarily so you can see it in such a small area. But it shows what happens as weld shrinkage and panel movement pull at the surrounding area. In the bottom view, the red line depicts where the crown was originally.
[IMG]https://hosting.photobucket.com/images/y167/rmccartney/weld%20gaps%20lose%20crown.jpg[/IMG]
With tight butt welds we do need to planish in order to remove any deformation caused by shrinking, and add some stretch back into the area. This should be the extent of our planishing effort, as the tightly fitting panels prevent the panel pull from adjacent areas (that a gap allows, resulting in loss of crown). In the case of any gappage around a patch, we would need to planish even more to add enough stretch to overcome this loss of crown, or add filler as needed.
Looking at the quarter panel in the video, and welding that took place, one would expect in the case of a normal butt weld that the edges of the panels against each other will be a positive stop against any pull from adjacent areas. The only planishing we should need to do is to overcome any shrinking issues due to weld heat. While the theory looks good on paper, the angle cut did indeed close up the gap when compared to a straight cut. But it did not totally eliminate it. My concern with this type cut is that two angled surfaces do not provide the positive "stop" that a truly butted panel does in preventing panel pull from adjacent area. After the grinding process is done, checking the weld seam with a 6" ruler may show how flat that single weld is, but our main concern should be the crown across the entire patch to see if it has pulled inward causing a loss of crown. A defect such as that will be a pain to correct, filler or otherwise. I'm not intimately familiar enough with the method to say this will indeed be a concern. But these thoughts are more cautionary, to give you things to be aware of, to look for.. if you do give this method a try.. For the quarter panel, I would expect any shrinking/panel pull to cause the following issues to the crown:
[IMG]https://hosting.photobucket.com/ima...aps%20lose%20crown%20quarter%20panel.jpg[/IMG]
…..and to a lesser extent, the slight crown from front to back, as the weld shrinks, will pull slightly inward. Armed with this theory on shrinking and panel pull, these are merely things to look out for. More planishing perhaps may be needed to remove any defects that might show up.
I used this method to fix multiple holes in firewall. Worked well I thought.comments
Fast- 1/2 hour
Some shrinking issues but controllable with more experience
Firewall thickness was very forgiving
Thinking of trying on cab corners and back wall of cab
37 Chevy 1.5 ton
17 Dodge Brothers Roadster
23 Dodge Brothers Touring
23 Dodge Brothers Coupe
73 Plymouth Scamp 2 dr
