8 members (‘37ChevyPU, Hotrod Lincoln, Otto Skorzeny, CuzzFuzz, Shaffer's1950, SlimSix, TrknGMC, 1 invisible), 81 guests, and 3 robots.
Topics128,139
Posts1,056,451
Members48,441
Where can I find a diagram or picture that identifies the terminals on a 1959 6 cylinder ignition switch? I know I can remove the switch and wire terminals to identify them, but I'm trying to avoid removing the switch again.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
This may help. It's for a 55 2nd series, but I'll bet it's very similar.
Wiring diagram
Thanks for trying to help. However, what I'm trying to find is a diagram or picture of the terminal locations on the back of the switch. My eyesight isn't that great and I cannot read the tiny, faint lettering on the switch. It is a foot start, as are all six cylinder TF trucks. Only the V8s are key start.
Oldbolter
If your ignition switch has three positions (on, off, momentary start), the switch is the same as I posted (attaching an enlarged version.) If it's only 2 positions, it will have just the three terminals that bartamos mentioned, one battery, and two switched terminals both on at the same time.
If it's three position and you have a foot start, it may just not have the start terminal wired.
Hope that helps.
Klhansen, thanks for the diagram. I'll be back in the shop today for more fun wiring my '59.
Oldbolter
