4 members (klhansen, Hotrod Lincoln, Hush, Tronman), 71 guests, and 2 robots.
Topics128,206
Posts1,057,435
Members48,471
I searched, but did not result in the answer was looking for. I will need new front fenders, my rear fenders are blasted and patched, but will take lots to get to a finish level, so I am considering replacing them. So, I am looking at reproduction fenders.
What can I expect from reproduction fenders in the way of fitment? What have you had to modify to make reproduction panels fit. I have heard lots of horror stories and complaints, but not everybody can be using original metal (even though that seems to be the recommended route).
The rear fenders mate to a flat surface (no radius, no body lines) so short of bolt holes not aligning I would think these might be easier. I have seen videos where they have to take a slice out of the front fender adjacent to the mounting flange to the get the panel gaps to modern standards. I need panels not to rub, but am not looking for a perfect show car restoration. I consider my project to be a ground up reconditioning instead of a ground up restoration of 60+ year old work truck that hopefully can be used again functionally.
Thanks in advance for you reply or you sending me to other links.
1956 Chevrolet 3800 Long Bed
Follow this build in Tons o' Fun
Sir Searchalot
Sir Searchalot
Well Paul........... it's all available at the normal aftermarket places. Price Approx., with shipping, $550-$750 each. Better and cheaper to find local donors. Also, patching is what some of us do. A fender that already fits, fits. Several patch panels are available for your front and rear fenders.
All above is here >>>>>>>>>> https://www.classicparts.com/ Located in the "MIDWEST".
You can buy donor fenders that need fairly easy dent/crack repair, and bang/weld on them yourself.
Lastly: Several times I have purchased whole trucks and sold off the pieces I don't need. Final price for my parts..$0
You need the space and the wife for that.
If you bought a truck that needs all four fenders, I hope you got it for a good price. wink
Bartamos,
My fenders are already patched. I have a good line on where to find the new parts. I am comfortable with what I paid for my truck, it needs to be saved.
Just curious to here feedback from someone who has used reproduction fenders.
I bought repo rear fenders for my 53 one ton, and they fit very well and look good. I also bought one front fender, which fit pretty well and looked good. It was slightly trickier getting the front fender installed, but the repos seemed to be good. I bought mine from Jim Carter.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
