| | | Forums66 Topics128,125 Posts1,056,339 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2020 Posts: 87 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 87 | Someone please help. I am not getting spark from my coil. Here is what i have done: 1. put in a new coil 2. new wire from battery to positive side of coil
when i turn the engine over, hold the coil wire, which goes to the distributor cap, close to ground i get no spark.
did i get a bad coil? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Turn on the key & put a screw driver across the points. Each time the points open & close or the screw driver grounds the points you should get a spark. Make sure the points open & close as the engine turns. Sometimes the rubbing block gets worn down to a point where the points won't open. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2020 Posts: 87 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 87 | Thanks George, points do spark when i stick a screwdriver in there. Points do open and close as the engine turns over. The points look new. I've never heard the engine run but the guy who sold it to me said he drove it last year. | | | | | Joined: Mar 2020 Posts: 87 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 87 | Well, after a few hours of fiddling with the engine, i'm suddenly getting spark at the plugs. something must have been loose. Now i need to figure out how to set the timing with the engine not running. i know the distributor was moved and the timing is off. is there a way to do this? | | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | Rotate the engine until number 1 cylinder (closest to the radiator) is at top dead center with both valves closed and then back off about 6 degrees or so (turn the other way a bit). Turn ignition on, install a timing light between the number 1 plug wire and the number 1 plug. Turn distributor until the timing light flashes and stop. Tighten the distributor, start engine, loosen distributor and set timing using the flywheel and timing marks on it. Good luck.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Mar 2020 Posts: 87 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 87 | Thanks Jon, appreciate it. | | |
