4 members (Steelonsteel, tclederman, NH46COE, Pete1946), 152 guests, and 10 robots.
Topics128,077
Posts1,056,032
Members48,433
#1352967 04/02/2020 9:27 PM
There are 3 terminals on the original ignition switch on 47 Chevy truck. One goes to the Battery post on the voltage regulator, one connects the coil and gas gauge, and one is not connected to anything. How do you tell which is which?
Also my gas gauge slams to full when turn the key. What am I doing wrong? Thanks for any advice! David
P.s. I am rewiring my panel with the lesser expensive harness from Jim Carter. It’s a nice unit but the instructions leave a lot to the imagination of a wiring impaired installer like me.
1949 Chev 3800
1947 truck Shop Manual - labelled light switch page.
The illustration of the light switch is attached below.
Insomniac
Insomniac
Hey, Tim! Do you have a picture of the ignition switch?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Oops - sorry for my odd/incomplete response (and, I did not yet have my evening drink). Gord
If I can find a link, I'll post it here. [image has been attached, and, link posted below]
1947 Chevrolet Truck Electrical System
Ignition switch, Accessory Terminal (Empty, switched on with ignition key)
AD Addict & Tinkerer
I had the same question with my ‘52 chevy 3100. It wasn’t hooked up on my truck. I ohm'd it out and when the ignition is switched on (and it’s only a two position switch, off/on) both terminals are powered. I suppose the accessory terminal is for a lighter or maybe the radio.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks everyone! Very helpful information! David
1949 Chev 3800
Sir Searchalot
Sir Searchalot
It does not make any difference which terminal is used for battery hot. If it did, these AD ignition switches would be marked.
