7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible),
85
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Hi, I installed a Pertronix Ignitor and a flamethrower coil on my 235 do I still need the wire from the foot starter to the coil? Thanks Steve | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you still have the resistor in the circuit, you will need the wire for a bypass. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Try to provide more information in future posts. 1. Presumably you still have a 6v negative ground electrical system in your Chevrolet (?) truck? Presumably you have a 6v negative ground Pertronix module (what part #)? If both presumptions are correct, you do not need "the resistor". What resistor, and, where is the resistor? 2. Possibly you have a 12v conversion negative ground electrical system? Presumably you have a 12v negative ground Pertronix module (what part #)? If both presumptions are correct, I think you do not need a resistor in the starting circuit. I think that Pertronix has diagrams somewhere on their website? I'll look for them after you clarify what you have - or, you could look for them on Pertronix's website. If I am incorrect/incomplete, someone will correct/clarify. This Installation Manual might help - but, I cannot read it. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you still have the resistor in the circuit, you will need the wire for a bypass. George For George & Steve: what resistor, and, where? I have seen/read-about "ballast wires" between the ignition switch to the coil; and, I have seen ballasts resistors in the lead from ignition to the coil; and, I have seen "ballasted" coils (VW, I think)? | | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Hi, motor is a 1959 235 12 volt neg ground with the voltage regulator still there on the fire wall. I will look for the part number on the Pertronix today I could not find any info about the wire from the foot starter to the coil on the pertronix site but will do some more digging . Thank you all for the response. I don't have the wire from foot starter to coil hooked up a little slow cranking at first before motor starts.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The resistor on that model is a ceramic unit on the outside of the firewall near the v.reg. & horn relay. Read the directions on the Petronix carefully. Some combinations use a resistor in the circuit & some don't. It is important to get the right setup. The last one I had was a 56 I put Petronix on. I used the resistor. It worked fine, started instantly but I accidently left the key on without the engine running one time when I was testing lights. Over night it blew the coil wide open.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Hi, No resistor on the firewall at all looks like there never was one mounted. Tim it is a 1168LS and a 3.0 flame thrower coil. I will do some more research on this. I am not to good with the electrical stuff but I am learning. I will call the tech department on Monday. Again thanks for the help. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That is a 12v negative ground unit. No ballast resistor is needed. Installation Instructions(scroll down for full size pages) | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | With Pertronix, when you use their Flamethrower coil, you do not need a ballast resistor or the wire from side terminal. Positive coil terminal gets Pertronix red and ignition "ON". Two wires.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Ditto. No resistor needed. But do make sure you are using the right coil. Some pentronix ignitions used 3.0 coils, some used 1.5 coils. Besides that easy peasy. And if you leave the key on. Yep coil will fry. | | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Thanks for all the info It is my Son's truck I will tell him about not to leave the key on without it running. It is almost ready to take to him in Ft Lauderdale I don't think it will happen any time soon with what is going on. Again thanks for the help! Steve | | | | | Joined: Dec 2016 Posts: 80 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 80 | I just put this system in my 59 w/235. No resistor needed as the Pertronix system requires 12 volts. The resistor was used to knock down the voltage after the engine started to 6-8 volts to protect the points and condenser. I had the resistor on the firewall and did a bypass on the backside of it so it gives the appearance of originality. It is a great upgrade to go to the Pertronix system, runs so much smoother!
1959 3204 Basic Cab
