9 members (Peggy M, JoeDude, Hotrod Lincoln, Perro, 48jim1ton, Shaffer's1950, Stovebolt48, Donf, 1 invisible), 93 guests, and 3 robots.
Topics128,032
Posts1,055,516
Members48,425
#1352841 04/02/2020 2:20 AM
My 261 has an updraft carb and the air intake tube wraps around the engine to where the oil bath filter used to be. I put a K & N filter on it some years ago, but wondered if it's getting enough air. I've seen the small filters on single barrel carbs and original updraft carbs, but much larger filters on the stock downdraft types. The intake tube has only a 2 in diameter, so I've had a difficult time finding a larger element. Could Deve or someone else let me know the correct size to use please. Thanks
1958 Chevy Grumman Olson step van
Chaz 58 #1352850 04/02/2020 4:28 AM
I am no Deve, but the key to being able to get away with a small modern filter is the airflow rating of the element material in that filter.
Putting a paper air filer designed for a lawn mower in an original small filter seems like a dandy idea, but that filter doesn't allow enough air through it. It is designed for an engine with one or two cylinders in very dusty conditions (thus extra small holes in the paper, which restricts airflow).
What are the specs for your K&N filter?
You can test to see if a filter is too restrictive with a tachometer. At idle, check the RPM with the filter on, then with it off.
You can also do a performance test by driving like you stole it with the filter on, then with it off. You will need to rely on the seat of your pants to make the judgement of a difference.
Carl
Chaz 58 #1354181 04/09/2020 2:03 PM
The filter seems a little restrictive compared to no filter. Enough so, I am looking for a larger air cleaner.
Chaz 58 #1354468 04/10/2020 10:59 PM
This is good info. Never thought about check the RPM's at idle with and then without the air cleaner on.
Craig
Chaz 58 #1354753 04/12/2020 2:24 PM
So at idle, do the rpms increase with a filter on versus no filter?
Craig
Chaz 58 #1354907 04/13/2020 12:46 AM
Low air flow = slower RPM...take the restrictive filter off and the RPM will go UP.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
