4 members (Ponchogl, TUTS 59, Otto Skorzeny, Hotrod Lincoln), 128 guests, and 1 robot.
Topics128,126
Posts1,056,353
Members48,441
#1352602 03/31/2020 4:31 PM
As I sit around cooped up waiting for the weather to break, I'll throw out the question on if it's possible to add power steering to a 59 1-ton Chevy? All stock up front with 235 6-cylinder. I'm guessing there really isn't a good way to do this, but thought I'd start the discussion. Thanks!
1959 Chevrolet 3800 Pickup
1937 Chevrolet GC Panel
Can you still call it a barn find if it's your barn?
Rustbucket Ranch
Rustbucket Ranch
I believe back in the day, power steering was a option for the bigger trucks, but those systems are rarer than hens teeth.
I'm pretty sure its possible to modify a system to make it work on these trucks.
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
Offline
Offline
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
24601
Still gotta ask ... What are you trying to gain by doing so?
Most of us who have merely rebuilt and properly adjusted our stock/original front ends (spindles, bearings, tie rod ends, king pins and steering boxes) find that we end up with steering that is pretty close to power assisted with out the expense and effort. My 1-ton goes down the road straight and nice at 65 MPH and steers pretty good at slow speeds, too. I completely redid the front end on a 1.5-ton (4400) and could steer that truck at a low crawl on dirt with one finger.
Just an option to consider as it sounds like you have a pretty original truck. It would be a shame to go to all that trouble just to find out that gains over keeping it original (but rebuilt back to original specs) were marginal (IMHO).
There are a few (very few) reasons to go with power steering -- such as medical condition, etc. But barring any of those... you might try checking out someone's truck who has rebuilt their front end to see what their steering is like before you go to a lot of expense and effort.
Just food for thought ...
smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
7
7 Offline
According to the GM heritage info and the 1957 shop manual, power steering was an option on the bigger trucks, it was not the modern style as we see today. The power assist incorporated a hydraulic cylinder with remote valving, the cylinder connected to the tie rod and a fixed mount at the other end. My 1978 Corvette has the same style. With or without a load on my '57 LCF I have no problem with ease of turning, the design works fine for me.
Thanks guys, for the comments. The truck is stock all around, so I would only add power assist if it could be put on without irreversible modification. The truck steers fine when driving, like the other non-PS vehicles I've driven, but it would be nice to have a little help at slow/no speed turning.
I did find this setup listed on FB Marketplace. It's listed as being from a 59 Chevy truck. It appears to match the parts diagrams that I have, except possibly for cylinder mount by spring. Thoughts?
I realize that it's missing the pump mounted on the generator, but otherwise appears to be the power assist parts.
Moderated by  Dusty53
