Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (1955 1 Series, Otto Skorzeny), 111 guests, and 5 robots.
Topics128,277
Posts1,058,456
Members48,490
Has anyone had any experience with Patrick's mono-leaf spring set-up? They advise they work real well, but in researching this subject I came across Eaton Spring's advise against mono-leafs. My panel's not a hauler, I'd just like a smoother ride and a wee bit of lowering, 2 inches max. My other concern is wear on the U-joint with the stock torque-tube driveline, if the truck's lowered it will be flexing differently than designed for.
I got front monoleaf springs from CPP on my daily 1/2ton 52 chevy for 3 years now.
I drive freeways, city and bumpy dirt roads and can only say the very best things about them.
They have even more travel than the original (worn) ones and I never bottomed out.
I never worry about them breaking sooner than any other critical part under stress.
Like Eaton springs says, if springs are properly designed there is not a problem. These seem very well designed and could handle a lot more load.
I think Patricks sells the same ones and gets them from CPP.
On the rear I kept the original multileafs but used lowering blocks from Jim Carter.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
I thought I wanted monoleafs but first I tried removing the 2 bottom leafs out of the spring pak. I got more or less what you say you are looking for. The leafs are 1/4" thick so removing two gave me 1 1/2" drop of bumper height and a stance that I'm happy with. The ride smoothed out a whole bunch too. It only took one evening and a few washers under the u-bolts so it's worth a try. I was suprised the steering wheel changed 1/4 turn so even this minor alteration has quite an effect on steering geometry. Don't worry about the u-joint as lowering actually straightens out the drive from the tranny to the shaft.
You Tube
I've read Eaton's bit about monoleaf a couple times and have decided he has an axe to grind and some of his logic is either incomplete or faulty.
You don't want any poorly designed or manufactured parts in your suspension. But I am not persuaded by his arguement that monoleafs are inherently dangerous.
Patrick's has the multi-leaf with a couple leafs taken out. Drops the truck about two inches.
Question though. With a 2" drop does the Pitman Arm need shortening?
