3 members (2-Ton, 78buckshot, texczech), 236 guests, and 11 robots.
Topics128,078
Posts1,056,035
Members48,433
#1351541 03/25/2020 10:07 AM
Hello ,whith the confinement i’have ManyTime to ask questions
I’v a 54 1/2ton chevy whith a Gas tank behind the seat
My problems
A. when i’m riding The fuel gauge indicator (a new one)is always in mouvement.
And Parked i’m never sure the gasoline level is correct it’s indicate quite empty but i full it whith only 6,6 gal
It’s not precise enougth
Is there any modern Gas tank sender unit fit whith this old tank or other solution ?
B: My consumption is about 29 liters per 100 kms (9,74 mpg)What do you think about?
(Engine 235 cu)
Best regards Frenchie chevy
Insomniac
Insomniac
Hello Alain,
My fuel gauge bounces on rough roads when the tank is not full. I think that this is normal for these old vehicles.
Bending the sender float arm might make it more accurate. Of course, you have to remove the sender which is somthing I do not want to do. Instead, one day, I plan to siphon all the gas out and refill the tank while noting the gauge position. This way I will know how much gas I really have whatever the gauge reads.
10 mpg? Since you have stock transmission and gears, I am not surprised.
I watch France24 news. Sorry to hear what's happening in France with covid-19. Please take care.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thanks for your reply and support
Alain frenchie chevy
Similar to what Gord said, to me, knowing that the gauge is accurate when you get down to say 1/4 tank is most important. Thus I would empty the fuel tank completely. Then put in exactly 4 gallons which is 1/4 of a tank. Check the readings. If not directly at 1/4 tank, I would remove the sending unit and bend the pivoting arm accordingly.
Obviously you also need to make sure the float is not leaking.
Craig
Sir Searchalot
Sir Searchalot
The old system is not precise. Hard to make it precise. Just calculate the tolerance +/- and act accordingly.
You are getting 8.11 MPG. Very bad.
To maintain 20% reserve fuel. Drive a maximum of 182 KM after fill up.
Hello
Thanks for replys
What is a normal consumption ?
Ex Hall Monitor
Ex Hall Monitor
You don't say what speed you're driving. The faster you drive the worse it'll be.
I agree with both Bartamos and Tiny.
You MPG low low.
What RPM or speed, and what type driving (steady speed or start-and-stop)?
steady-speed driving, I get:
16-18 mpg 45-55 mph
12-14 mpg 55-65 mph
3.55 rear ends
1954 235 & 1960 261 truck engines
Insomniac
Insomniac
The truck has the stock rear end. (from previous posts)
Check timing and check vacuum advance is working OK.
Gord 🇨🇦
Hello
I’m Not able to give RPM
For the speed it’s about 50 55 mph on the road
31mph on the street
3.90 rear ends. 54 235cu
Mainly short distance 1,8 -2,4 miles smooth driving
15 MPG is what you should be getting, given your specifications. Do your spark plugs develop black soot on them? A malfunctioning carburetor will do that. It is receiving too much fuel, most of it goes out the tailpipe unburned, greatly reducing fuel economy.
Make sure that your liter-to-gallon and kilometer-to-miles conversions are correct.
One thing is
Perhaps the odometer is Not correct while my tires are 6,50 R 16 instead of 600 R16 or other reasons
I will use à GPS To be sure of kms
Amitiés à vous tous
A good speed app for your phone is Speedbox.
Craig
