| | | Forums66 Topics128,079 Posts1,056,297 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2020 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 59 | Hello ,whith the confinement i’have ManyTime to ask questions
I’v a 54 1/2ton chevy whith a Gas tank behind the seat My problems
A. when i’m riding The fuel gauge indicator (a new one)is always in mouvement. And Parked i’m never sure the gasoline level is correct it’s indicate quite empty but i full it whith only 6,6 gal It’s not precise enougth Is there any modern Gas tank sender unit fit whith this old tank or other solution ?
B: My consumption is about 29 liters per 100 kms (9,74 mpg)What do you think about? (Engine 235 cu) Best regards Frenchie chevy | | | | | Joined: Jul 2000 Posts: 2,195 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,195 | Hello Alain, My fuel gauge bounces on rough roads when the tank is not full. I think that this is normal for these old vehicles.
Bending the sender float arm might make it more accurate. Of course, you have to remove the sender which is somthing I do not want to do. Instead, one day, I plan to siphon all the gas out and refill the tank while noting the gauge position. This way I will know how much gas I really have whatever the gauge reads.
10 mpg? Since you have stock transmission and gears, I am not surprised.
------------------------------- I watch France24 news. Sorry to hear what's happening in France with covid-19. Please take care.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2020 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 59 | Thanks for your reply and support Alain frenchie chevy | | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | Similar to what Gord said, to me, knowing that the gauge is accurate when you get down to say 1/4 tank is most important. Thus I would empty the fuel tank completely. Then put in exactly 4 gallons which is 1/4 of a tank. Check the readings. If not directly at 1/4 tank, I would remove the sending unit and bend the pivoting arm accordingly.
Obviously you also need to make sure the float is not leaking.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The old system is not precise. Hard to make it precise. Just calculate the tolerance +/- and act accordingly. You are getting 8.11 MPG. Very bad. To maintain 20% reserve fuel. Drive a maximum of 182 KM after fill up.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2020 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 59 | Hello Thanks for replys What is a normal consumption ? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You don't say what speed you're driving. The faster you drive the worse it'll be.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I agree with both Bartamos and Tiny.
You MPG low low.
What RPM or speed, and what type driving (steady speed or start-and-stop)?
steady-speed driving, I get: 16-18 mpg 45-55 mph 12-14 mpg 55-65 mph
3.55 rear ends 1954 235 & 1960 261 truck engines | | | | | Joined: Jul 2000 Posts: 2,195 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,195 | The truck has the stock rear end. (from previous posts)
Check timing and check vacuum advance is working OK.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2020 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 59 | Hello I’m Not able to give RPM For the speed it’s about 50 55 mph on the road 31mph on the street 3.90 rear ends. 54 235cu Mainly short distance 1,8 -2,4 miles smooth driving | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | 15 MPG is what you should be getting, given your specifications. Do your spark plugs develop black soot on them? A malfunctioning carburetor will do that. It is receiving too much fuel, most of it goes out the tailpipe unburned, greatly reducing fuel economy. Make sure that your liter-to-gallon and kilometer-to-miles conversions are correct.
| | | | | Joined: Mar 2020 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 59 | One thing is Perhaps the odometer is Not correct while my tires are 6,50 R 16 instead of 600 R16 or other reasons I will use à GPS To be sure of kms Thanks Amitiés à vous tous Alain frenchie chevy | | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | A good speed app for your phone is Speedbox.
