Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (baldeagle), 117 guests, and 2 robots.
Topics128,274
Posts1,058,432
Members48,489
#135237 08/30/2006 3:37 AM
I have a 54 chevy 1/2 ton. I bought a power steering conversion kit and a power steering box. Any tips for installation or where to mount everything. I am unsure how to do this. Does anyone have any pics of this being converted? Any help would be great! thanks in advance!
1954 Chevy 3100. Original 235 and Hydramatic
www.cardomain.com/ride/2344117
There is more than one kit approach out there. Which one did you buy?
It is the one from chevy duty. part #76-977 the description is "Includes brackets and instructions for adapting late model power steering box to truck.
Places the steering box on the outside of the frame in front of the axle. steering shaft passes through the inner fender skirt after you make a small notch in the skirt at the bottom. Must order a Pitman Arm, Part# 76-986 and a u joint kit. If using the original steering coluum you must order a Conversion lower bearing 76-987."
Here's a link to Brother's online guide to their installation of that kit (or a similar one)
http://www.brotherstrucks.com/techa...7-1959%20POWER%20STEERING%20INSTALLATION
