5 members (Charles in CA, Millenimech, Maybellene, IHPWR, Shof), 105 guests, and 2 robots.
Topics128,034
Posts1,055,540
Members48,425
#1351994 03/27/2020 11:22 PM
Y
Olddog
Olddog
Y Offline
I own a 1948 GMC 1/2 ton, put a 305 w/alternator, 12 volt
System. Question: do I need reducers on all my gauges?LMC truck said Not on amp gauge, how about Oil gauge, temp gauge, fuel gauge, aren't they all mechanical?
Bought a EZ wire 21 circuit harness, I assume this harness will be fine. Just wondering about these reducers. Any help most appreciated.
Yankabilly.
YankaBilly #1351998 03/28/2020 12:14 AM
Crusing in the Passing Lane
Isn't fuel guage electric? Temp gauges come both ways, is there a Cu tube going to a sensor in the head or electric wire on sender?
Ed
I don't use a reducer on the original fuel gauge. I have found that the biggest issue with bad readings with 12 volts is due to improper bends in the sending unit float arm, not the applied voltage.
Sir Searchalot
Sir Searchalot
Your gas gauge is electrical.
If you are all mechanical except the gas gauge, you can do like Carl or buy this.
You will have to tell us, if you have mechanical. As said, if the under hood sender has a tube instead of a wire, it's mechanical.
The 305 V8 would have electrical senders. So if you have original gauges, someone had to adapt 1948 to 1973, and up, compatibility.
Y
Olddog
Olddog
Y Offline
I would like to say thank you to each of you for your help, it is much appreciated!
Yankabilly.
