2 members (Frank50, Kilted54), 71 guests, and 4 robots.
Topics128,189
Posts1,057,222
Members48,465
Good morning! I am restoring a '40 chevy 1/2 ton. It appears that part of the body that is on either side of the radiator core support is spot welded to the support. Is this accurate? Can I use a spot weld cutter to separate the pieces even though the core support is much heavier gauge steel?
Thanks in advance for any info.
Yes, you can use a spot weld cutter to separate the pieces. Cut thru the thinner metal. I'm assuming you're trying to replace the body panels with new, since you're talking about removing them from the core support. If you'd like advice about repair (maybe weld to good metal on those panels in lieu of cutting them off), post some pictures of what you're dealing with. I'm sure that someone will help out.
Sir Searchalot
Sir Searchalot
Agree with Kevin....what is the reason for separating these components? Is it absolutely necessary?
As he says, the answer is yes the way you describe. I can't see the situation but you would drill out the spot on the thinnest piece.
Some good well lighted pix would be great.
I have some pics of my 40 when it was apart
Are you talking inner fenders or ?
Email me. [email protected]
1940 Chevy KC 1/2-Ton
