2 members (ndkid275, ronsway), 168 guests, and 3 robots.
Topics128,089
Posts1,056,139
Members48,435
Hi All, Newbie here. i just bought a 1950 Chevy PU. I can't get it to shift into reverse. I pulled the top cover with the shifting forks and lubed everything. I got 1-4th working but reverse is stuck. any suggestions?
Thanks for any help, Mike
When you try to put it in reverse, hold pressure on shifter and let clutch pedal out slowly. Wil it go into reverse with the engine off?
ASU Offline
Mike,
I assume your truck has a Muncie SM420. It should have this shift pattern. When you are in neutral, between 1st and 2nd, you should be able to pull the gear shift toward you and feel a slight spring pressure resistance as it moves toward you
Jon
Thanks for responses, the shifter assembly is removed from the transmission so there is no issue with synchronizing the gears. I also assume this is an SM420. Movement between 1st through 4th is smooth. Yes, there is spring-loaded tension once I move to the left of Neutral.
Mike
By the way, this is the truck i'm starting with. Glass is in front and back, rebuilding driver door now.
Got it working today and reinstalled it. It was just stuck. you'll notice the spot rust on some of the guts. obviously, water got inside when the windows were not installed. Thanks again for the comments. Next, no spark. Gotta figure that one out.
Blessings all,
Mike
Crusing in the Passing Lane
Whenever one comes across a gearbox cover like yours or worse, get some walnut shells to sandblast the rust off, any remaining shells will do no damage.
Ed
Oh i thought it was a runnig truck. Well good luck. Keep us posted
That looks like a great project. With my four speed, sometimes to get it into reverse I have to move it forward a bit.
1951 1 Ton Completed
