9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible), 125 guests, and 0 robots.
Topics128,114
Posts1,056,283
Members48,439
#1351178 03/22/2020 7:03 PM
Has anyone found a supplier for these? (Actually all 3600's may be long bed, not sure they made a short bed....anyone know?) I may have to cut and paste from several pairs of short bed versions I have. What have folks been doing for replacements?
Allen
1974 Stingray Corvette
24601
Allen, I've not been made aware of any supplier for running boards or valance/filler panels for any AD truck other than the 1/2-tons. The only two sources I am aware of are either finding used ones or fabricating a set from several sets of half-ton boards (like you are considering).
As for "long" versus "short" beds on AD pickups, the Chevrolet Truck Data Book tells us that each rated size pickup only came in one bed size: the 3104 (1/2-tons) have 78-in beds; the 3604 (3/4-tons) have 87-in beds; and the 3804 (1-tons) have 108-in beds. Calling them "long" or "short" is not actually meaningful nomenclature.
Good luck finding a set -- they are out there but getting harder to find. And they will probably be $$$ when you do.
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Thanks John for clarity on bed lengths.
Allen
Aprons would be pretty easy to fab up, assuming a sheet metal roller and brake (and the appropriate dimensions) are available. I hauled up a 3-in-1 (roller, shear, press brake) machine for a friend last spring from the lower 48.
Running boards are another story. Since they taper from front to back, even splicing together from 2 sets would be an iffy proposition. It could be done, but I'm guessing it would be a relatively difficult project.
Fox Offline
On my 1 ton I did what Kevin suggested and splice things together. However, mine are not originals and do not have the ribbed top. They are flat all across the top. I got one large piece of sheet bent to the bends I needed. I then had to cut them and then reweld them together to get the taper I needed both front and rear for the dually. It was a pile of work. The single wide running boards were easier to fab up.
I have an old build thread here:
https://www.stovebolt.com/ubbthread...ad/Board/45/main/163250/type/thread.html
Hopefully the old phtotbucket links work. Grrr.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Yes PB did work, thanks for posting. Good looking project.
Allen
