0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#135122 08/21/2006 8:26 PM
I have a 1935 1 and 1/2 ton truck and would like to put a more modern straight front axle in it. Just wondering what years will bolt right in?
#135123 08/21/2006 8:28 PM
I forgot to add...I want to make this into a 1/2 ton street rod.
#135124 08/21/2006 10:00 PM
frame is a bit heavy for a 1/2 ton. Do you want 5 or 6 lug wheels? Disc brakes? a 1941-1955 1st series axle should be a bolt in replacement. they have larger king pins than the earlier axles. You may have to do a lot of suspension work for those axles to bolt in, those springs should be a lot heavier than 1/2 ton springs.
if you want disc brakes, you should be able to get them for the later axles.
for a streetrod, you might be better putting one of those f@*d thingys there, from a cost perspective.
#135125 08/22/2006 7:36 PM
I would prefer 5 lug wheels. Disc brakes are not a real issue fo me. I am just looking for a 1/2 ton bolt in replacement for the old heavy 1 and 1/2 ton front axle.
