0 members (), 123 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
I'm looking for a detailed picture of a crankshaft gear for a GMC 228 or similar engine showing the timing mark. My camshaft gear has a mark however my crankshaft gear does not. Obviously this is necessary to properly time the engine during assembly.
Search Ebay for "GMC 270 timing gear". There is an auction showing a slightly rusty new old stock crankshaft gear with the timing mark visible. Also, check your PM's. I can walk you through a method of timing a cam with no marks at all, but it will take a phone call to do that.
Edit:
The same timing gear also fits a Chevy 216/235/261.
GM NOS part. I think the same as one you have. But confirm.
Todd
1950 Chevy 3100
Thanks for the info guys.. I also found a diagram in the shop manual.
