10 members (TUTS 59, KEVINSKI, Hotrod Lincoln, Geo55, Dusty53, Gray_Ghost, Gdads51, Otto Skorzeny, Wayne67vert, 1 invisible), 123 guests, and 2 robots.
Topics128,165
Posts1,056,992
Members48,458
I'm looking for a detailed picture of a crankshaft gear for a GMC 228 or similar engine showing the timing mark. My camshaft gear has a mark however my crankshaft gear does not. Obviously this is necessary to properly time the engine during assembly.
H Online: Content
Search Ebay for "GMC 270 timing gear". There is an auction showing a slightly rusty new old stock crankshaft gear with the timing mark visible. Also, check your PM's. I can walk you through a method of timing a cam with no marks at all, but it will take a phone call to do that.
Edit:
The same timing gear also fits a Chevy 216/235/261.
GM NOS part. I think the same as one you have. But confirm.
Todd
1950 Chevy 3100
Thanks for the info guys.. I also found a diagram in the shop manual.
