8 members (Hotrod Lincoln, carbking, tclederman, Bill Hanlon, 49choptop, Guitplayer, John L., Otto Skorzeny), 125 guests, and 4 robots.
Topics128,042
Posts1,055,501
Members48,424
#1350876 03/20/2020 10:26 PM
Do any of you know if the crank diameter where the rear seal rides on a 270 GMC is the same as a 235?
My Blog
H Online: Content
All the other crankshaft dimensions on a GMC six are the same from the 228 to the 302- - - -rod and main bearing sizes, etc. I've got a 228 stashed away I can measure in the morning once it gets daylight outside in the storage shed. The 235 is 3 7/8" diameter at the seal surface.
Thanks Jerry, that would help.
My Blog
H Online: Content
OOPS! That 228 still has a bellhousing, clutch, and flywheel installed. If somebody doesn't come up with a dimension for you I can do some disassembly and get the measurement you need.
Just checked the 270 broken crank end that now serves as a paper weight on my bench.
Diameter at the seal surface is 2.875"
Hope this helps...
Thanks much guys.
My Blog
H Online: Content
Thanks, Bob! I'm going to guess that the flywheel flange on the GMC is larger than the seal area, right? Chevy 216-261 engines use a straight crank hub without an oversized flywheel mounting flange, which is why I can machine the back of the block for a lip seal like a late model Chevy V8, a Ford Powerstroke, and most of the Caterpillar Diesel engines use.
Hi Jerry,
Yes GMC has a flange that is much larger than the diameter at the oil seal. It is approximately 5" in diameter.
Best Regards...
Bob
270 Crank
Thanks for the picture, that helps me a lot.
My Blog
H Online: Content
My Federal-Mogul shop specifications book lists the size of a std. diameter rear main bearing journal as 2.777" +/- around .0005". That makes the seal surface about 0.100" larger than the rear main.
