4 members (TUTS 59, 55shaker, Wrenchman, Oswald), 55 guests, and 1 robot.
Topics128,089
Posts1,056,010
Members48,430
#1350598 03/18/2020 10:26 PM
I was removing the transmission floor cover and had some trouble with the clutch screws. The driver set I have has sizes 3/16 and 1/4, but one is too big and the other too small. I got the 3/16 to work, but I feel that if the screws had been really tight I could have easily stripped them. Once I got them out I tried cleaning them (thinking that maybe they were just full of paint and stuff so the 1/4 would not drop in), but that did not help. My question is am I doing something wrong? Or is there a 7/32 size out there somewhere?
I could grind the 1/4 inch down a little bit if necessary.
Thank you,
Lee.
1956 Chevy 3200, 235 w/3 speed
LeeD #1350705 03/19/2020 6:07 PM
Lee,
My two cents worth: the new clutch head drivers are a hair off the original size, maybe just mass produced?. I did shave a hair off two of my ( socket set) drivers to make a tight fit.
I also bought a NAPA set (screwdriver style) they seem to fit better than the socket set.
Todd
1950 Chevy 3100
LeeD #1350707 03/19/2020 7:07 PM
Would a piece of emery cloth tighten the grip enough?
Ed
LeeD #1350712 03/19/2020 8:15 PM
Lee,
I don't think there is 7/32 size in clutch head, at least I have not seen a fastener that size on my trucks. My drivers are from NAPA, somewhat pricey, but fit very well the fasteners on all my Chevys.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
LeeD #1350758 03/20/2020 2:51 AM
Here is what sizes I have in my collection. 5/16. 1/4, 3/16, 5/32, 1/8, 3/32.
LeeD #1350794 03/20/2020 12:26 PM
Thanks for all the replies, sounds like my best bet would be to go to NAPA and find a good set. In the meantime I’ll grind a little bit off the other set to make them fit.
Lee.
LeeD #1350848 03/20/2020 6:23 PM
Rustbucket Ranch
Rustbucket Ranch
I have a set of clutch head bits, but have also ended up using a regular flat screwdriver to remove some clutch head bolts when the bits didn't have a snug fit and was worried about rounding them out.
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
LeeD #1350858 03/20/2020 7:41 PM
I tried to save as many of the clutch head screws I found on my 50
Don’t think I ran into the oddball size
LeeD #1350936 03/21/2020 7:39 AM
I bought a set of cheap clutch head drivers from a chain store and they didn't fit Chevy screws. So I got the set from Classic Parts and they worked perfectly.
1951 Chevy Panel Truck
LeeD #1350953 03/21/2020 12:39 PM
I am in Dallas for work (enjoying all the closed restaurants!) and won’t be home for a couple of weeks. I’ll try grinding down the 1/4 inch and see how that works. Maybe I can find an open NAPA store around here and buy a set. It would be nice to have a set that will fit in my magnetic screwdriver; my current set only works with a 3/8 ratchet.
Thanks again,
Lee
LeeD #1352915 04/02/2020 3:56 PM
Possum and Todd are correct, I have my fathers clutch heads (about 60 years old), and a set I purchased for my mechanic. The new ones seem a wee bit loose (Amazon). NAPA would be more than likely the best choice. Basically I believe all who responded are right. So why did I send this out. I have four generations of tool's maybe I should share with my Stovebolters.
Is there a "show us your old tools" Thread?
BC
1960 C60 pasture art
LeeD #1352923 04/02/2020 4:45 PM
Definitely would be a good thing to post in the Tool Chest forum. Old tools are cool.
LeeD #1353011 04/03/2020 1:54 AM
I'd like to see pictures of homemade tools used on these trucks. I have a few.
LeeD #1354659 04/11/2020 11:29 PM
I went to like 6 different places looking for a set of drivers, no one even knew what they were untill I went to this place that reminded me of an old parts house. lots of paper parts catalogs, they not only knew what I wanted they had a set, some well come loose with out rounding out but most I break loose with vise grips and replace with new hardware
woof359 Family 1952 3100 5 Window
