6 members (Hanks custodian, Chris's 46 / 515, carbking, Goach2, mick53, 1 invisible), 69 guests, and 6 robots.
Topics128,188
Posts1,057,215
Members48,465
Hello,
Recently purchased a 1956 Chevrolet 6400 V8.
Most wheels are the Firestone RH-5. Read through the tech tip wheels thread and it mentioned posting future info on the 6 lugs but didn't see any updates.
What options are out there if I decide to run the OEM running gear?
Also found the master cylinder leaking out the rod seal. Any recommended sources for parts?
Thanks, Dan
Welcome to the Stovebolt wave
Finding 22.5" (one piece tubeless) 6-lug Budd rims is way easier than finding the 5/10 lug rims. Place an Ad in the Parts Wanted Section here and check with your local big truck junk yards...those rims were used for many years...don't overlook old school buses.
The rebuild kits can be found at your local NAPA, you need to confirm the size (cast on the side of the MC)...1-1/4"? If the MC is pitted real bad than it can be sleeved in brass or SS. Do a google search and see who does it in your area. I know White Post Restorations in Virginia does it.
Does your truck still have the original 265 V8 with a 4+2 trans/rear setup?
We love pictures pix
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
It does not have the original engine. Looks to be a 1972 350 with hei and 4bbl from a '78. Exhaust manifolds I'd guess are original as I've never seen any like these before with front cross over but the RH manifold is shot. Has correct short waterpump, late model 12V alternator(improperly shimmed). My guess is original 4sp and 2sp rear axle.
Pic of truck on way home, getting off loaded and test fitting a bench seat from a regular cab S10.
Looks pretty solid...The hood emblem is 1955.
Was this a Fire Engine at some point in it's life? Unusual to see chrome turn signal lights on top of the fenders, most were painted black.
What type of body are you going to install?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
That's a nice looking truck. Looks like you found a good one!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
No clue on its history.
For that matter it's actual year either. Turns out it was cab swapped decades ago and the vin tag is for a 3100. Wasn't planning on hauling heavy anyway. Bought because it was in decent shape, rust wise.
The original chassis serial number found on the cab A-post tag is also stamped on the frame. It's found on top of the drivers side frame rail right above the front axle and will have the Year, Plant and Unit number...the series code was not stamped on the frame...
Sample 56A001234
A 6400 will have a 154" wheel base and be coded "6B", so the cab tag would look like this...6B56001234.
The front fender emblems are 1956...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike.
I'll try and get the numbers off the frame tomorrow.
The cab vin starts with 3A57511xxx and has a gvw of 5,000 instead of 16/18,000.
Sir Searchalot
Sir Searchalot
Cab swap or Vin plate swap to match a title they had. Cab or plate is 1957 1/2T with 6 cylinder. The 6400 truck was a V8.
Frame ID: 56S023812
Was definitely cab swapped a long time ago.
Sir Searchalot
Sir Searchalot
What do the Vin Plate rivets look like? Do the numbers match the Title?
Bill of sale, will be titled as the 57 my guess.
All tags look original. Cab was a different color. Very old repaint.
If the front V8 engine brackets are riveted to the cross member than it was a factory V8, (if bolted it's a conversion and was born a 6-cylinder) and the Cab tag serial number would start with a "V" (not stamped on the frame)...
So the trucks chassis was either born V56S023812 as a V8 truck or 56S023812 as a 6-cylinder...
V = V8
6B = 2 ton 154" wheel base
56 = Year
S = St Louis
023812 = Unit number atarting with 001001
Your Cab 3A57511xxx breaks down as follows...
3A = 1/2 ton short step side
57 = year
5 is a typo...bet it was "S" = St Louis
11xxx = Unit number starting with 100001
Sending you a PM
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Thanks for info Mike.
I'll start another thread about the truck in general.
Mike,
IIRC, there was a symbol on the frame preceding the VIN but I just thought it was a artifact from the #stamp, but it could have been in a "V" design. Will check later.
I have some wheels, PM me.
Last edited by 69Cuda; 03/20/2020 4:48 PM. Reason: no selling allowed in the tech forums outside the for sale area.
