5 members (32Fordpuchoptop, treegrower, Jon G, Danielbolt, 1 invisible), 194 guests, and 3 robots.
Topics128,078
Posts1,056,053
Members48,433
#1349899 03/14/2020 4:28 PM
Hello. Sorry if this is a frequently asked question, but what's the best way to clean the rust or coat the inside of a 1959 gas tank? It's out of the truck and I've gotten the loose chunks out. No leaks yet, so what can I do to either neutralize what rust is left or coat the inside so I'm not plugging the fuel filter? Thanks for the help!
1959 Chevrolet 3800 Pickup
1937 Chevrolet GC Panel
Can you still call it a barn find if it's your barn?
People have reported using various techniques.
I had my fuel tanks professionally cleaned/coated (when I lived near two radiator/fuel-tank shops).
here is a discussion about cleaning/sealing fuel tanks
Riding in the Passing Lane
Buy a new tank.
1972 Chevy c10 Cheyenne Super
Second Wrenchbender’s suggestion.🛠
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
By the time you pay to have it cleaned properly and pay to have it sealed or seal it yourself, you could have bought a new tank.
A new tank is priceless in terms of piece of mind.
V
VEW Offline
V Offline
I've done it both ways: cleaning and coating (personally and professionally) and buying new. As others have recommended, buying a new tank is the only way to go. They are available and not that expensive.
~ Victor
1957 3100 - moved on
I have cleaned and coated original tanks twice. The last tank was my 1965 C10 tank. I used the KBS tank cleaning and coating system and the whole process went very well. I’m very pleased and have had no problems. It takes time and you will use acid and chemicals. A new tank is not a bad deal and saves time. Depends on your skill set, available time and budget.
