5 members (Uncles51, 55shaker, Woodcmiami, Stovebolt48, joe apple), 65 guests, and 3 robots.
Topics128,021
Posts1,055,351
Members48,420
#1349957 03/14/2020 8:37 PM
I should know the answer, BUT. My 51 has a 54 235 in it, while trying to get her going I noticed the fuel hose from the pump to the carb was showing its age, so I pulled it off to get a measurement. When I got back from the parts store I discovered the gas was running straight thru from the tank. Is this normal or a sign of a bad pump? This is a plain pump, no vacuum port. Also, with the engine running, the fuel just trickles into the filter at the carb, making me wonder if the pump is weak. I wish I had paid more attention to what it did I parked it. John
tinnerjohn #1349972 03/14/2020 9:53 PM
Gravity flow through the one way check valves in the pump toward the carburetor doesn't necessarily mean it's bad, as long as they seal going the other way. Doing the fuel pump volume/vacuum/pressure test that I've been recommending for years is the right way to check a pump, but to the best of my knowledge, nobody has ever bothered to listen to me on that one!
tinnerjohn #1349975 03/14/2020 10:22 PM
Thanks, I couldn't remember on the check valves, I'm trying to find my gauge. IIRC should be somewhere between 2-5 lbs. shouldn't it.
tinnerjohn #1350016 03/15/2020 1:51 AM
I listen to everything you say, Hotrod.
Sometimes I actually do what you suggest. smile
Don't take it personal. Some of us (most of us) can be hard headed.
Carl
tinnerjohn #1350024 03/15/2020 2:20 AM
Your running hose from fuel pump to carb?
Typically, metal tube is used
tinnerjohn #1350031 03/15/2020 2:46 AM
It came with the hose. I plan to replace it with metal when I get the bugs worked out.
tinnerjohn #1350033 03/15/2020 2:51 AM
Sounds good
There use to be a video on this site that shows a glass filter.
Fuel just trickles in.
Search LonnieC “fuel filter “. It might show up
Test is a good idea
tinnerjohn #1350036 03/15/2020 3:01 AM
Found his video
...link....
