| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | I should know the answer, BUT. My 51 has a 54 235 in it, while trying to get her going I noticed the fuel hose from the pump to the carb was showing its age, so I pulled it off to get a measurement. When I got back from the parts store I discovered the gas was running straight thru from the tank. Is this normal or a sign of a bad pump? This is a plain pump, no vacuum port. Also, with the engine running, the fuel just trickles into the filter at the carb, making me wonder if the pump is weak. I wish I had paid more attention to what it did I parked it. John | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Gravity flow through the one way check valves in the pump toward the carburetor doesn't necessarily mean it's bad, as long as they seal going the other way. Doing the fuel pump volume/vacuum/pressure test that I've been recommending for years is the right way to check a pump, but to the best of my knowledge, nobody has ever bothered to listen to me on that one! Jerry
| | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Thanks, I couldn't remember on the check valves, I'm trying to find my gauge. IIRC should be somewhere between 2-5 lbs. shouldn't it. John | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I listen to everything you say, Hotrod. Sometimes I actually do what you suggest.  Don't take it personal. Some of us (most of us) can be hard headed. Carl
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Your running hose from fuel pump to carb?
Typically, metal tube is used | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | It came with the hose. I plan to replace it with metal when I get the bugs worked out. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Sounds good
There use to be a video on this site that shows a glass filter. Fuel just trickles in.
Search LonnieC “fuel filter “. It might show up
Test is a good idea | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Found his video ...link.... | | |
