1 members (Brian Moore),
95
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 96 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 96 | Can anyone recommend a good valve spring compressor for my 216 head. I bought a cheap one from harbor freights but didn't really work out.
Colton Kenshol Hermiston, Oregon
1950 Chevy 3100 216 Motor Mostly Original..
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Buy a used professional-grade tool on Ebay. Snap-On, Kent-Moore, K-D tools, etc. There are bunches of them there, and they never wear out. I've been using the same air-operated valve spring tool for over 30 years. There's one identical to mine listed under "used valve spring compressor" today for $30.00 along with a bunch of others. Jerry
| | | | | Joined: Jan 2020 Posts: 96 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 96 | Thanks Jerry.. I really won't need one very often but would be nice to have one handy
| | | | | Joined: Jan 2020 Posts: 96 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 96 | Jerry... What makes and model of spring compressor do you have..
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | I think it's a Snap-On. I'll need to dig it out of storage, as I haven't used it in a while. It looks identical to the one that's on Ebay. Air power helps out a lot, when someone is doing production work and maybe working on several cylinder heads a day. For a hobbyist, one of the lever action types would be adequate.
Do a quick copy/paste, before the link gets zapped:
https://www.ebay.com/itm/VINTAGE-CLARK-FEATHER-CF-700-PNEUMATIC-VALVE-SPRING-COMPRESSOR/153858128496?hash=item23d2a8ba70:g:UsAAAOSwxdVeZB6H
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Most parts stores have loaners. I used one from one of the local FLAPS on my '216.
