1 members (Leo),
125
10
Mod | | | Forums66 Topics128,077 Posts1,056,019 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | I finally got the T-5 installed on my 52 chevy. Everything seems to be working great but now there is a noise coming underneath the cab. The noise goes away if you tighten the clutch linkage (pull the throw out bearing as far away from the pressure plate fingers as possible) until you shift it a couple times while driving. The driveshaft was cut too short but I do not feel any wobble. I am getting one made but is it possible there may be another problem? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Did you cut the collar & front shaft off on the T-5? Did you get the pilot brg. back in the crank far enough? Is the trans hitting the floor? Did you put a mount on the rear of the trans.? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i believe you have to as the wrench says trim down the pilot shaft and round collar that are present on the T5 for users of 216 & 235 motors. larger motors do not need this which larger motors I can't remember. certain;y a 250 and 292 do not need this done. 261? 230's ?
anyone know ??????
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | The T-5 pilot shaft and collar were trimmed down to match the original 3 speed. I did not replace the pilot bearing. Could having the pressure plate on too tight cause this? I did not use a torque wrench on it. | | | | | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | I did not put a mount on the back of the transmission. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Overtightening the clutch bolts will not hurt untill one breaks. Some bolters claim they have been running them for a long time without a rear mount with no problems. I put an aftermarket crossmember with a mount mine. That long aluminum tranny is not made to hang like that. I can,t imagine what that noise is. I,ve heard the floor on the AD,s are pretty close to the trans. If it is contacting it it would make noise. Did you check the pilot bushing? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Could the t-5 need some rebuilding,bearings ?? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | I am pulling the driveshaft tonight to have a new one that is the correct length built. While I have the driveshaft out I will start up the truck and run it through the gears and see if this is a vibration from the driveshaft being too short. I will also pull the flywheel cover and take a look at the throwout bearing (it is a new bearing) to make sure it is releasing and engaging properly. Hopefully I will have an update tommorrow. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Can you run the transmission through the gears safely without the output yoke installed?
I sort of thought the extension housing bushing and yoke held the output shaft steady, not to mention sealing the housing from flinging oil.
Stuart | | | | | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | I have an extra yoke that I will put on the tranny before running it through the gears. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What,s going to keep that yoke from flying off ? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I was afraid to ask that same question! Stuart | | | | | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | So... You guys are saying this may be a bad idea. Guess I will just adjust the linkage and wait for the new driveshaft. Thanks for the input. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | that's my read on this post.. be careful, or you might damage or be missing some body parts!!! yours and the trucks.
I'm assuming it's also a one piece driveshaft? remember that 2 piece drive shafts must have the ujoints properly phased (lined up) or you will get vibration.
