| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 10 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 10 | have a 1953 Chevrolet 3800 with a 216. besides the 235, are there any other engine options? | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Tim, I think he is asking about an engine swap - not factory options in 1953. 235 and 261 would be the easiest and most straight forward swaps.
Professional Novice
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Frank - then, you have answered his question. I'll add: 1954 and later 235 and all 261 engines would be more modern engines, with the higher pressure oil lubrication system. 1954 and 1955st series 235/261 would be the easiest swap, because 1955nd and later 235/261 engines would require the relocation of the water pump. The 1953 or earlier clutch housing will need to be used to fit the 1953 and earlier motor mount crossmember with later 235/261 engines. I'd used the 1953's standard-equipment rear-transmission mount on that earlier (1953) frame crossmember ( that cross member was not used/needed on 1954 and later trucks). | | | | | Joined: Oct 2015 Posts: 10 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 10 | thank you for the reply. what engine code would i be looking for on the 1954 and 1955st series 235/261 engines? | | |
