10 members (Jay R, moparguy, walterhvogel, JW51, Jon G, Gray_Ghost, Stovebolt48, 55shaker, HelmutVonSchet, 1 invisible), 73 guests, and 0 robots.
Topics128,079
Posts1,055,941
Members48,430
#1349303 03/09/2020 1:39 AM
have a 1953 Chevrolet 3800 with a 216. besides the 235, are there any other engine options?
homeinspect #1349317 03/09/2020 3:26 AM
two engines in 1953 - 216 & 235
If you go to that link, you will see that the standard engine on a 3800 was the 216.
A 235 was not available a RPO.
To find out if your truck has the original 216 engine, find and post the head/block casting codes and date codes and engine serial number.
homeinspect #1349407 03/10/2020 12:10 AM
Tim, I think he is asking about an engine swap - not factory options in 1953. 235 and 261 would be the easiest and most straight forward swaps.
Professional Novice
homeinspect #1349422 03/10/2020 1:40 AM
Thanks, Frank - then, you have answered his question.
I'll add:
1954 and later 235 and all 261 engines would be more modern engines, with the higher pressure oil lubrication system.
1954 and 1955st series 235/261 would be the easiest swap, because 1955nd and later 235/261 engines would require the relocation of the water pump.
The 1953 or earlier clutch housing will need to be used to fit the 1953 and earlier motor mount crossmember with later 235/261 engines.
I'd used the 1953's standard-equipment rear-transmission mount on that earlier (1953) frame crossmember (that cross member was not used/needed on 1954 and later trucks).
homeinspect #1349431 03/10/2020 2:06 AM
thank you for the reply. what engine code would i be looking for on the 1954 and 1955st series 235/261 engines?
homeinspect #1349432 03/10/2020 2:10 AM
find and post here the various codes (1, 2, 3, and 5, 6, 7) shown on this page
