0 members (),
124
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | I have a low mileage 350 crate engine with a Weiand spreadbore intake going in a '52 3100 and I need to know where to look for a professionally rebuilt quadrajet. I need to know which one to look for. I want to go with an electric choke, but I have not been able to find a non-electronic Q-jet which comes with the electric choke. The crate motor is one of those Mr. Goodwrench hecho en Mexico engines which was manufactured in 1992 and is said to be 250 HP.
| | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Have you tried any of the online "hot rod" retailers? Jegs and Summit probably have pages of spread bore carburetors. I know you asked about a rebuilt, but sometimes a new one can be competitive price wise.
SimS | | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Carl - have you considered the aftermarket Carter TQ? With about 150,000 carburetors to choose from, I have one on my own 350. However, since I detest electric chokes, I use a manual choke version.
Sent you a PM
Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can put an electric choke coil in a carb that has the round plastic choke. 78-81 models with out electronic controls work good. Put a cap over the vacuum tube. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | It's easy to fit an later model choke cover to an early Q-Jet. The problem is finding one for a Chevy engine that has the integral choke in the carburetor. Most of the OEM Chevy carbs have a divorced choke mounted to the manifold heat riser passageway. I have used a carb for a Buick 350 at times, and converted the choke cover to the electric heated type. Don't use the gasket under the cover- - - -it prevents the heater coil from getting a ground, and plug off the vacuum port to prevent a constant leak. Route the voltage through an oil pressure switch so the choke heat shuts off in case the engine stalls during warmup. Jerry
