2 members (Otto Skorzeny, 1 invisible), 92 guests, and 2 robots.
Topics128,031
Posts1,055,433
Members48,422
#1349241 03/08/2020 12:47 PM
OK what am I missing? This is a Delco Remy distributor on a 1956 261 in a 2 ton 6100. How do you get this apart or at least to tighten on the points and condensor connections? When I go the tighten the nut on the outside of the distributor the inside head spins and pushes the connections off.
...click...
Do you have a side view of that terminal?
I figured I would need a special tool but thought I would ask anyway . I don't have a pic of the side but it does have a split nut on the outside captured in the insulator. I guess I'll have to sacrifice an out screw driver. Thanks for the info, I couldn't fins that yesterday when I was searching.
There are replacement terminals available
...click...
Just in case
Vintage Truck & Tractor
Or check out "The Brillman Company". They have alot of odd antique car parts
Current project; 1961 C20, 235 I6
same price as at Steiner (DADS50's post, above)
Insomniac
Insomniac
Dev's tech net describes a distributor rebuild. http://devestechnet.com/Home/Project1959235#distributorrebuild
Be careful to avoid breaking the plastic parts. It might be possible to replicate that special screw by grinding down the head of a standard screw.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Check Ebay. There are usually several of the dedicated tools for that job available. Some of them also have the 11/32" nut driver to fit the outer nut built into the opposite end of the handle. I've owned several of those tools over the years.
Edit: There's one of those tools on Ebay today, but they're asking $25.00 for it. A simple work-around is to take a short piece of 1/4" steel tubing and file or grind the end to form a pair of tangs that engage the spanner nut. Drill the other end for a handle made from a short piece of steel round stock.
If you look inside the insulator, you will see a ring slot nut. Uses a special tool, has ring slot nut driver on one end, regular nut driver on the other. Couple of photos of some of the tools that were sold. They turn up on eBay regularly enough that you should have no problem finding one. or you can make one out of a short wide blade screwdriver by cutting a slot in the middle to clear the stud and engage the slots on either side.
So when changing the points, you take the nut, wire and small wire shield off, then loosen the ring nut, remove the points, install the new points and condenser wire, tighten the ring slot nut, the install the rest of the hardware and coil wire.
KD2025
Mac SC4
Snapon MD17
Others made them as well.
Mike
Distributor Tool
One tool is easily home-made - adapt/cut a small screwdriver
a better photo of the tool
KD tools 2025
Insomniac
Insomniac
I have pliers like this. Useful for this type of thing and other purposes...
https://www.tekton.com/6-inch-70-degree-bent-long-nose-pliers-pgf10406
Gord 🇨🇦
A cheap set of snap ring pliers with right angle tips would work for that nut as well.
NAPA Link
Thanks for all the responses. I did end up getting it off. Used a pair of needle nose vise grips to hold the bolt from spinning and then used a pair of snap ring pliers to remove the split nut. As it turns out the little plastic haunch on the inside of the insulator was broke off which let the bolt spin when trying to undo the split nut. I went and bought the replacement insulator from Steiner on my lunch break.
