1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
Page 2 of 2 1 2
#165998 08/04/2007 3:13 AM
You guys mentioned the steering column color, my take on that it is more of a brown, the color codes I have from Bob Adler is DuPont 8540 or PPG 27627. I am of the understanding this color was used on the column, column gearshifter, and steering wheel! And I believe it, because if you look at the reproduction horn buttons (from GM, by the way) the color on those is exactly the same brown as the numbers above. At least in my eyes. Would not the steering wheel color have matched the horn button?
#165999 08/04/2007 1:05 PM
No, the horn button would be the same as the interior panels, the steering wheel, mast jacket, gearshift lever and shaft (if present) should all be the same gloss non-metalic gray/brown, a difficult color to discribe. I believe this is the color that Bob Adler is refering to, i.e., PPG #27627, is that correct????
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#166000 08/04/2007 2:16 PM
The interior panels are the same color as the seat upholstery, maroon. Is that the color of the horn button? I had the DuPont number made up, it is brown, I do not know what the PPG number is, but Bob says they are interchangeable.
Lots of guys believe the steering wheel and column are the same color as the cab interior, that is probably why you see that so much in restored trucks. But even Jim Carter admits the wheel and column are a different color. Ask him.
#166001 08/04/2007 2:44 PM
Finally got a confuser up and running that will allow me to handle graphics again. Here are a couple of pictures of some interior parts that were sprayed with the PPG DBU/DIU #27467 "Graphite Brown Metallic". I used a PPG DP-90 LF (black epoxy) primer under all the paint.
The light reflection makes a big difference in the way the shade looks. As it was explained to me, the new metallic paints use a different metallic flake and this gives it the difference you see. Head on the shade is a very close match but when viewed from an angle it appears darker than the original.
In the left door picture the inside of the door has been repainted, including the window garnish, the door sill plate and the seat skirt, the rocker and pillar has not. You can also see the original mast jacket color in this shot.
http://rides.webshots.com/photo/2711529160098611668JiSKic
In the right side picture only the inspection panel, window garnish and seat skirt has been repainted, you can clearly see the differences in the way the light angle affects the way the color appears in both pictures. The skirt and rocker are almost identical in the right side head on shot, but the window garnish and inspection cover look much darker.
http://rides.webshots.com/photo/2006570340098611668xqlsjY
Denny Graham
Sandwich, IL
Brian, I'm not an expert here, just reporting my findings and personal observations. I'm not really sure what your talking about when you say that the interior is painted Maroon. All I have ever seen is the Brown Metallic interior color in the AD's. Maybe someone with more exposure can help you out.
Denny G
Sandwich, IL
#166002 08/04/2007 3:39 PM
This is good "STUFF". Thanks for all the hard work Denny, & guys. It's a win, win situation, when we work together like this to solve these truck tech. situations.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#166003 08/04/2007 5:17 PM
By "interior panels" I am referring to the cardboard door panels with the naughehyde covering, which matches the seat covering. I thought that when you said interior panels that is what you meant. I agree with you about the cab interior, the "champagne", or brown metallic, whatever that color is called is correct. I am only saying I believe the column and steering wheel is a different color. Quite different.
#166004 08/05/2007 4:35 AM
Denny I dont see a link to the pictures of the interior parts painted you make reference to in the above post can you send me a click on link to check them out
Ken
#166005 08/05/2007 3:29 PM
Sorry bout that Ken, I’m hooked up to the net through a phone line and average about 30,000 bps speed, that’s SLOOOOoooow. I spend hours trying to upload and view graphics, so I get them mixed up once in a while.
Re-check that reply, I edited it and added the links.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#166006 09/04/2007 10:57 PM
I'd be willing to bet that the factory applied interior color varied a bit between batches of paint. As long as the entire interior was painted from the same batch, who'd know? I think that's why the steering column was a slightly different colour - they were painted in a different spot in the factory, and from a different batch of paint.
That's my two cent's worth, anyway. :whistle:
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
#166007 09/05/2007 5:00 AM
The mast jacket and wheel are a solid color, not metallic Tom. It is a also a different shade than the cab interior.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Is this right for the interior?
Looks darker than what's left on my seat riser.
http://images.tcpglobal.com/chips/1951-Chevrolettruck-pg09.jpg?linkingParam=%7B%22_ga%22%3A%22GA1.2.1534082798.1524315223%22%7D&_ga=2.194658981.982743817.1524315327-1534082798.1524315223
Hi everyone,
Looking to resurrect this thread. I’m looking for the correct paint code for the dash and doors of a 1949 Chevy 3100.
This thread has great info BUT all the picture links showing the colors are dead. Any assistance on correct “Champaign” dash paint codes and of course functional picture links would be awesome.
FYI My truck is getting painted next week forester green
Thanks!!
Thanks Dad550. There’s some good info but no paint manufacturers or paint codes In the thread you listed.
Has anyone used this and if so do you have any pictures you could post?
https://www.classicparts.com/mobile/1947-53-Interior-Cab-Paint-Champagne/productinfo/31-014/
I found a thread by Denny a few years back which I think answers my questions. Thank you Denny!!!
Here’s a link to pictures posted by Denny if it helps others:
https://pbase.com/dennygraham/image/123581933
I’m fairly certain PPG 27467 IS the correct color. Now I have to see if I can get it
Ok.
Tim’s link on the second post has color names and old ppg codes
http://1954advance-design.com/Advan...%20Tech%20Tip%20--%20Paint%20Colors.html
Not sure if it current
Cannot be any more help than that
I rattle-caned my Interior
Wowzers that’s a rattle can paint job?!? That looks perfect!!! If I can’t find the PPG then I’ll follow your example and do the same.
Thanks again Dads50, appreciate all the help
Rustoleum rattlecan paint flows unbelievably nicely. I did my '49 with it and it came out just like Dads50's (who I unashamedly used as a source as to what to do. Thank you Dads50!).
Carl
I got most the info from here and deves old site
Your right , the paint covers well, on my doors I scuffed and painted right over the blue.
Wow, I'm pretty stoked about this. Between the two local hardware stores they have both Rust-Oleum colors.
Ill add what I used on gauges
I have not been able to find a match for the pale peach color of center part of gauge.
Dads50, I’m amazed how well a “rattle can” paint job can be, thank you for posting the pics and the actual paint cans. Being armed with this information makes it so much easier to replicate what you’ve done on your truck.
You rock!
You could get get better results by spray gun
I don't have a show truck so the rattle can worked for me.
Its a budget option
Good luck
One other small tip for anyone restoring gauges
Don't get paint on the inside housing where the fuel gauge mount. This area needs to be clean bare metal. It is the ground path. It is a mistake many of us have made.
The instrument lights ground on the housing also.
Tape off the ears of the housing also so they can complete the ground path to the dash.
Sorry O.P. Way off your original question
Denny has a little info on interior paint on his 50 ...click...
...click...
...click...
I don't think the op will mind. Hasn't been seen since 2007.
I did start my own interior project using your advice dads50. Couple pics here including one of yours. (Hope that's ok, tried to pm you but your mailbox is full.)
thumbs_up
Before I tell my painter to buy the Dads50 Rustoleum paint (which looks killer), wanted to ask one more time if anyone has used the interior paint from classic parts; and if so, do you have any pics you could post of what it looks like.
That paint won't match to a "T", because it's missing one. wink
"CHAMPAGNE INERIOR"
Great catch Kevin! I didn't even notice that.
There are a few pics on this post of that classic parts paint
....link.RdsLessTaken..
Looks good to me, the guy post about it being “very low gloss”, where I live thats a good thing.
Thanks for the link to the pics Dads50, The pics are a bit dark but "CHAMPAGNE INERIOR" looks like the stuff smile
Here are a couple more pictures of Classic Parts interior cab 1947-1953 “champagne” #31-014 paint. My truck was painted about 7-8 years ago, it’s always possible suppliers have changed. Exterior color is Mariner Blue. Seat cover, door panel covers, arm rests are from Jim Carter.
Page 2 of 2 1 2
Moderated by  ndkid275, Phak1
