2 members (3B, Cosmo), 149 guests, and 3 robots.
Topics128,080
Posts1,055,951
Members48,430
#1349115 03/07/2020 8:33 AM
Is the cylinder head for a 1954 (truck) 235 (high water pump engine) , the same as the 1955 235 PG head (low water pump engine) ??
Dusty #1349120 03/07/2020 12:31 PM
Those cylinder heads should interchange.
They both use 18 head bolts - same sizes in same locations.
1953-62 235 heads will all interchange.
The 1953 head is not drilled for the four bolt valve cover, and the 1956 and later have a larger hole for the temp sender, also slightly higher compression.
My Blog
Thanks, as usual, for the details/corrections, Dave
Thanks guys , that's excellent info , just exactly what I needed .
