5 members (Oswald, FAST55, Bill Hanlon, 2 invisible), 85 guests, and 2 robots.
Topics128,075
Posts1,055,918
Members48,429
#1349009 03/06/2020 2:34 PM
I have a 1950 3100 and I am trying to sort out the fit of the hood and fenders BEFORE painting. Right now the hood still has to move rearward another 1/4 " and the front edge of the fender on both sides are in alignment with the front of the hood. at the rear the fenders are already at the offset in the cowl. Can they go past that offset to make the fender to hood look the best?? Any pictures you guys have of yours would be appreciated.
Thanks, Jerry
I've taken mine past the offset with no ill effects.
You must set the hood in the proper position before you can accurately adjust the fenders to fit the properly set hood.
You can set the hood correctly with the fenders off the truck. If the fenders are on the truck, they need to be lowered as far as possible to avoid influencing the adjustment of the hood.
"You can set the hood correctly with the fenders off the truck. If the fenders are on the truck, they need to be lowered as far as possible to avoid influencing the adjustment of the hood.
Excellent advice. Why didn't I do that with my Suburban 15+ years ago?
I'll know better if/when the pickup ever gets painted.
Someday, when I have 2 or 3 careful assistants, I will have to loosen all front sheet-metal attachment bolts, and, take out a few shims to lower the radiator. Hopefully, that will allow the front of the fenders to go lower, resulting in the front sheet metal becoming more "level".
Live & Learn (if you are lucky).
OK, so the hood is now in pretty good position. I installed a new rubber strip on the top of the cowl. It appears to be thicker than what I took off and as a result the hood sits a little higher than the cowl. Is this normal?
Which way did you put the seal on? The raised bead side goes against the cowl.
Does the hood edge sit high on the cowl the full length of the cowl?
Is the gap between the hood and the cowl the same width the full length including the outside, lower corners?
