10 members (JW51, Gdads51, artinva, Peggy M, VicZ, Ridgeback, RAC1812, Shaffer's1950, klhansen, 1 invisible), 122 guests, and 0 robots.
Topics128,077
Posts1,055,928
Members48,430
Hey guys, I just picked up a 1947 Loadmaster that has the 216 and 4 speed.
I am looking for what I may be able to do not wind her up so tight cruising around, I don’t wanna go cruising down the highway but maybe easily get to 50 mph.
I’m just learning my way around these so not sure where to start if I should try to throw in a new gear or finding a retro 5 speed to replace the old 4 speed.
Crusing in the Passing Lane
All those rear ends whether single or two speed only come with low or lower ratios. Is your truck '47 first or second series? A NV-4500 tranny will work, might have to drill and tap mounting bolt pattern in the front of 4500, easier to do if trans innards removed. Another option is a 'Brownie' 3 or 4 speed aux. trans if you have enough driveline room. Next size tires might help, try to get tubeless wheels and tires.
Then you have to be sure your brakes and steering are up to the increased speed.
Ed
62401
Is it a one ton? (3800)? or a 1.5/2-ton? (4000 or 6000-series truck*)?
If it's a 1-ton, you're in luck! Read This It's so easy, even I can do it (and I have ... smile ) Yah, sure, you can do the 5-speed tranny thing ... and deal with bellhousing adapters, cross members, blah blah blah. But with the rear axle third member swap, all you do is remove one and replace it with the other -- all you need to do is find one smile
If it's a 4000 or 6000 series truck (1.5 or a 2-ton), well .... I am not eager to disagree with Brother Pruss, but ... I must. (sorry Ed) ... You are simply out of Schlitz on that one unless you want to upgrade the engine. On the bigger truck, the 216 is simply not enough engine to push that weight around very fast no matter what gearing or brownie box you slap to it. Unless you live on flat ground and you like shifting ... a LOT. wink
No matter what, though, if you do get the truck to cruise faster, please also go through your braking system and your steering. You can safely cruise the 1-tons at modern road speeds with just the rear pumpkin swap, but you *must* have good steering and brakes to be safe.
smile
*If it was a COE/5000 series truck, I assume you would have made a point of saying so -- most COE owners do ... wink
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Moderated by  Dusty53
