5 members (Gdads51, Hotrod Lincoln, cmayna, Wooley, Otto Skorzeny), 118 guests, and 0 robots.
Topics128,113
Posts1,056,612
Members48,450
#1348206 02/28/2020 4:25 PM
I’ve got a 47 Chevy one ton panel. I posted some time ago about a rear differential guts swap to help ease strain on the engine and be able to highway drive the truck on occasion. I read through the articles forwarded to me from fellow bolters and started a search for the correct differential. I have found one from a 1968 Chevy 3/4 ton. Now, I’m not as savvy on gear ratios as many other gear heads, so I’m seeking advice about the parts I found to see if they will work before I commit.
The part # is GM 3817778. 11:41. Was told to divide 41 by 11 to get a value and it comes to 373. The gears are in very good shape and the price is right. I just don’t want to end up with a boat anchor instead of a smoother ride....
I appreciate any advice! Thanks, David
1949 Chev 3800
Leo Offline
Moderator
Moderator
David, you would be wise to move this post over to the driveline forum. I helped do this swap several years ago, fairly easy. Can't answer definitively your question.
24601
David,
Have you read our Tech Tip on this subject? Hopefully, you will find it helpful. The pictures in it were from the project Leo helped on, I think ... ?
The article should help you figure out if the one you have is the one you are looking for or not. The actual switch is pretty easy and can be done in a couple of hours and without having to jack the truck up.
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Leo #1348325 02/29/2020 3:40 PM
Yes that’s the article I have referred to . Great information. I just found out that the diff I found won’t work, so back to the hunt...
Thanks John!
1949 Chev 3800
