| | | Forums66 Topics128,065 Posts1,055,865 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I recall back in the 60's and 70's when all the guys would put in front axles for a stiffer suspension.That was the cool look, ironically now so many people install an independant suspension for a nicer ride.I actually partly bought this truck (53 Chev 1/2) cause it has the drop axle.I love they way these trucks ride, like a truck.Other wize I'd a bought a 57 Chev Belair 2 dr post.And yes I intend to install sex lites. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I like the ride of a real truck too, I've always seen it as you do-if you want a cushy ride,drive a car. There's getting to be fewer and fewer of us though,my friend,as the hold outs get arthritis and back trouble and can't take the pounding anymore. I'll tough it out until I can't drive at all. REAL TRUCKS RULE!!! Speed | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Back in the '60s they actually put straight axles under cars to get the front up. This was done for weight transfer, rather than stiffness. You'll see this mostly on Gasser class drag cars, but some street rods were done that way too, although that was more for the look than performance. By the way, take a good look at the '55 sedan from American Grafitti and Two Lane Blacktop (same car), it has a straight axle as it was originally built as a Gas coupe drag car.
Bill Burmeister | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Hey Bill,you are also right that they raised the fronts up for weight transfer.In order to get a wider tire under the back, they had to raise the back high enough to clear the tires.Unfortunately,then there was no weight on the back and the tires simply spun.Like you say, then up would go the front in order to put the weight back where it belonged, the back.So when you see a straight axle car, you just knew it was hot.Now they just tub them and unless you see them from the back, it's just another car. I have always been impressed by the axle cars and never really by the lowered ones. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The Gasser look is starting to make a comeback, especially on '55 Chevy sedans. It seems that there is at least one featured in Rod and Custom, Ol' Skool Rods, and Car Culture DeLuxe for the last few months. There are a lot of early Novas getting that treatment too. I like that look myself. I'd love to build one. With a Monster 572 in it.
Bill Burmeister | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Me too,after I finish mine,I was thinking of doing a tilt front end | | | | | Joined: Mar 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 113 | As a form of punishment I decided to do the same (tilt front AND bed) (WTH was I thinking?!).
On my '37 I went the performance route - tubular IFS, Z-28 TPI, 700R4, and a Jag rear.
"The things that don't kill you only make you stronger ;'}
Everything is different now...
| | | | | Joined: Mar 2006 Posts: 24 Junior Member | | Junior Member Joined: Mar 2006 Posts: 24 | my 59 apache long bed is on a wicked slant with coils all the way around and air shocks on the back end for when i need to tow a trailer. i wouldent want it any other way. | | |
